rnewman(at)lutron.com Guest
Posted: Thu Apr 27, 2006 5:18 am Post subject: Gear width and garage openings |
When we built our 3 Glastar's we did each of them in an area that
ultimately required us to roll thru an 8' wide garage door opening.
The gear on a Glastar is about 94" axel to axel when installed, but when
you add an engine, prop and all the other goodies it spreads to more
than 8'. The solution, which I believe will be applicable to the
RV-10 is to attach a ratcheting tie-down strap between to the two axels,
down low near the wheel and pull the two axels towards eachl together.
We were able to very easily spring the gear in and roll right thru the
door opening.
Bob Newman
