Vince Frazier
				 Posted: Thu Apr 27, 2006 5:53 am    Post subject: No Title |
				Kevin,
 We don't need no stinking RV-4 dimensions.  Do this.  More details are
 on the URL http://vincesrocket.com/finishing.htm
 1) make the wing fit the fuselage.  The limiting item will likely be the
 edge distance at the rear spar bolt holes.
 2) ignore whether the fuselage is level.  It doesn't really matter.
 Really, don't sweat it whatsoever.  Well, OK make it somewhat level from
 left to right so that your Diet Coke doesn't slide off, but fore and aft
 isn't important.
 3) level the wings to match the specs given i.e The data I have from
 Mark tells me to set the rear spar height 2.95" lower than the main spar
 when the fuselage is level.  (Except don't worry about the fuselage
 being level.)
 4) set the HS to Set the incidence on the HS using a 1/8" spacer on the
 front spar and a 13/32" spacer on the rear spar.
 5) marvel at your genius.  Mine flies straight.  Yours should also.
 Here's a tip that I think that you will like very much if you have the
 gumption to do it now...
 Ignore the instructions that say to put the VS on straight.  Why?  How
 many RVs or Rockets have you seen that DON'T have a rudder trim tab?
 Not very many I'll bet.  And they are always on the left side of the
 rudder aren't they?
 Well, mine doesn't have a rudder trim tab!  I mounted my VS on crooked.
 OH MY!  Yeah, well it works better that way.  Mount the rear VS spar as
 usual but mount the front spar so that the LE of the VS is about 3/8" to
 the LEFT of the fuselage centerline. =20
 Yes, that will make your store bought tail fairing not fit... but it
 won't anyway.  They never do.  Make your own and save time and money.
 Have fun.
 Vince=20
 F-1H Rocket, N540VF
 I am fitting my wings to the fuselage, (HR II) does anybody have a
 dimension for the wing incidence? Can't find anything on this in the
 vintage RV-4 plans I have.=20
 Kevin Shannon
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Rocket-List |
  _________________ Vince Frazier
3965 Caborn Road
Mount Vernon, IN 47620
812-464-1839 work
812-985-7309 home
F-1H Rocket, N540VF
http://vincesrocket.com/ |
