dmasys(at)cox.net Guest
Posted: Thu Apr 27, 2006 8:19 am Post subject: Autogas for 540 |
100LL hit a psychological threshhold at my home airport (JWN) this week. It is now at $5 per gallon. This got me thinking again about an autogas STC. Had one for my C-182 and flew it happily for 1100 hours on autogas, saving more than $10K at 13.5 gal/hr over five years.
Petersen lists autogas STCs for the following variants of the O-540, with those having an asterisk needing 91 octane and all others ok on 87 octane:
0-540-B1A5, -B1B5, -B1D5, -B2A5, -B2B5, -B2C5, -B4A5, -B4B5, -A1A*, -A1A5*, -A1B5*,
-A1C5*, -A1D*, -A1D5*, -A2B*, -A3D5*, -A4A5*, -A4B5*, -A4C5*, -A4D5*, -D1A5*,
-E4A5*, -E4B5*, -E4C5*, -G1A5*, -G2A5*, -H1A5*, -H2A5*, -H1A5D*, -H2A5D*, -H1B5D*, -H2B5D* -F1B5*
I was going to go with an IO-540 but it might be worth going back to a carburator to have a plane that is not hostage to the economics of greed, where every time autogas goes up 20 cents a gallon, avgas goes up a dollar.
Anyone else planning to run autogas in their Lycosaur?
-Dan Masys
#40448
GRANSCOTT(at)AOL.COM Guest
Posted: Thu Apr 27, 2006 8:24 am Post subject: Autogas for 540 |
Dan did you read this month's 100LL article in AvConsumer?
Interesting reading...
Patrick Scott
Tdawson(at)avidyne.com Guest
Posted: Thu Apr 27, 2006 8:38 am Post subject: Autogas for 540 |
Well, with injection you can lean that sucker out much more than with a
carb. It would be interesting to run the numbers comparing that
situation . . .
TDT
40025
GRANSCOTT(at)aol.com Guest
Posted: Thu Apr 27, 2006 8:45 am Post subject: Autogas for 540 |
I get to fly behind the IO 540 in a C 182 going slowly and using a good engine monitor G-1000 the best I can do is 9 gallons per hour doing 105kts..I know the frame of the RV 10 is better suited but are they're any STC for fuel injected 540's? If you're considering going the auto fuel route make sure all the parts between the tank and engine will not react with the added materials in auto gas...alcohol's and dispersant's...
Patrick
tie-norman(at)comcast.net Guest
Posted: Thu Apr 27, 2006 8:53 am Post subject: Autogas for 540 |
It is my understanding that these STCs were intended to use alcohol free
fuel (i.e. no methanol or ethanol). This may be an issue since MTBE is
being phased out and replaced with ethanol.
http://www.eaa.org/education/fuel/knopp_alcohol.html
Tommy
cehoffman(at)bellsouth.ne Guest
Posted: Thu Apr 27, 2006 9:49 am Post subject: Autogas for 540 |
My experience with the O-540 has been that the 235 hp versions run well on
auto fuel, but the 250hp and 260 hp versions tend to ping.
Cal
bsponcil(at)belinblank.or Guest
Posted: Thu Apr 27, 2006 10:05 am Post subject: Autogas for 540 |
I'm thinking it as well. Keep in mind however, that the choice in engine
isn't the only factor in safely running auto-gas. For instance, the
Cherokee 235 with the 0-540-B4B5 has the autogas STC whereas an Apache
running the very same engines does not. The same can be said for the
mooneys and comanches. Pull the engines out of those planes and put them
into a cherokee 180 and you go from no autogas to autogas approved.
According to Petersen, the tighter the cowl and the higher the performance,
the harder it was to pass their tests. I guess in the case of the mooneys
and comanches, they had problems with the fuel boiling in the carb. If I
remember correctly, one of the tests was to heat the fuel tanks (seems sort
of dangerous) to 110 degrees and then do a MaxPerformance climb all the way
to 12,500. Any hiccups in performance (loss of power, fuel pressure, etc)
and it failed the test.
Does that mean if you fly conservatively, ie - don't do maximum performance
climbs to 12,500, you won't have problems? I don't know. I think auto-gas
is a possibility in the RV-10s, but someone is going to have to be the beta
tester
-Brian
#40497
N211BD
Iowa City, IA
rnewman(at)lutron.com Guest
Posted: Thu Apr 27, 2006 10:34 am Post subject: Autogas for 540 |
Part of my plan is flexibility in choices, I'm using an O-540-E4B5 in
RV-10.
-Bob Newman
octane:
-A1A5*, -A1B5*,
-D1A5*,
a dollar.
-Dan Masys
#40448
Posted: Thu Apr 27, 2006 10:44 am Post subject: Autogas for 540 |
Maybe time to start really considering something other than a Lycosaur!
JG, #409
| Quote: | From: Dan Masys <dmasys(at)cox.net>
Reply-To: rv10-list(at)matronics.com
Subject: Autogas for 540
Date: Thu, 27 Apr 2006 16:18:42 +0000
-A1B5*,
-D1A5*,
-Dan Masys
#40448
rvbuilder(at)sausen.net Guest
Posted: Thu Apr 27, 2006 11:11 am Post subject: Autogas for 540 |
Isn't this the Bombardier engine before they split off?
Michael Sausen
RV-10 #352 Working on Fuselage
Recent RV-10 Build Activity
Posted: Thu Apr 27, 2006 11:28 am Post subject: Autogas for 540 |
Correct-a-mundo.
I remember seeing the V Engines at Oshkosh 2003. And I thought avionics certification was slow and painful!
TDT
40025
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Sent: Thursday, April 27, 2006 3:10 PM
Subject: RE: Autogas for 540
Michael Sausen
rick.conti(at)boeing.com Guest
Posted: Thu Apr 27, 2006 11:47 am Post subject: Autogas for 540 |
I've never owned a plane with an auto-gas STC. How do you refuel the
plane? I wouldn't image the wings would fit under the canopy of an
Exxon station.
Thank You
Rick Conti
Senior Engineering Manager
The Boeing Company
office: 703 - 414 - 6141
blackberry: 571 - 215 - 6134
n8vim(at)arrl.net Guest
Posted: Thu Apr 27, 2006 12:25 pm Post subject: Autogas for 540 |
You can use a pickup truck (remember those? They came before SUV's and
are often seen free-range roaming around farms) with a fuel transfer
tank in the back. Those tanks tend to hold a few hundred gallons.
You will have to swipe your credit card a few times to fill up though
(the pumps here in town stop at $75, and you have to start over again).
Imagine, the luxury of your own fuel truck!
-Jim
do not archive the preceeding humor
Exxon station.
Thank You
Rick Conti
The Boeing Company
jjessen
Posted: Thu Apr 27, 2006 12:42 pm Post subject: Autogas for 540 |
Yep
Sent: Thursday, April 27, 2006 12:10 PM
Michael Sausen
-----Original Message-----
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Tim Dawson-Townsend
Sent: Thursday, April 27, 2006 1:51 PM
--> RV10-List message posted by: "Tim Dawson-Townsend"
--> <Tdawson(at)Avidyne.com>
We need to show these guys how big the homebuilt market is. They've been ignoring it in favor of the OEMs . . .
http://www.vaircraftengine.com/
http://www.aero-news.net/index.cfm?ContentBlockID=9f2a2c16-1451-479a-ad6
1-40eec3d4b353&Dynamic=1&Range=NOW&FromDate=04%2F24%2F2006&ToDate=04%2F2
7%2F2006&Category=%2Findex.cfm
TDT
40025
[mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of John Gonzalez
Sent: Thursday, April 27, 2006 2:44 PM
--> RV10-List message posted by: "John Gonzalez"
<indigoonlatigo(at)msn.com>
JG, #409
--> RV10-List message posted by: Dan Masys <dmasys(at)cox.net>
week.
| Quote: | It is now at $5 per gallon. This got me thinking again about an
autogas
| Quote: | STC. Had one for my C-182 and flew it happily for 1100 hours on
autogas,
| Quote: | saving more than $10K at 13.5 gal/hr over five years.
with
| Quote: | those having an asterisk needing 91 octane and all others ok on 87
octane:
| Quote: | 0-540-B1A5, -B1B5, -B1D5, -B2A5, -B2B5, -B2C5, -B4A5, -B4B5, -A1A*,
-A1A5*,
| Quote: | -A1B5*,
-D1A5*, -E4A5*, -E4B5*, -E4C5*, -G1A5*, -G2A5*, -H1A5*, -H2A5*,
-H1A5D*,
-H2A5D*,
| Quote: | -H1B5D*, -H2B5D* -F1B5*
greed,
| Quote: | where every time autogas goes up 20 cents a gallon, avgas goes up a
dollar.
-Dan Masys
#40448
RV10-List Email Forum -
more:
bsp;
HREF="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
bsp; - NEW MATRONICS LIST WIKI -
bsp;
HREF="http://wiki.matronics.com">http://wiki.matronics.com
bsp; - List Contribution Web Site -
bsp; -Matt Dralle, List Admin.
HREF="http://www.matronics.com/contribution">http://www.matronics.com/contribution
LIKE2LOOP(at)aol.com Guest
Posted: Thu Apr 27, 2006 12:44 pm Post subject: Autogas for 540 |
In a message dated 4/27/06, rick.conti(at)boeing.com writes:
<< I've never owned a plane with an auto-gas STC. How do you refuel the
plane? >>
Rick,
My C-170 has an STC for auto gas. We get it at a local grass strip,
self-serve pumps, Indiantown (X58). The only Boeing's that land there seem to
be 6 Stearmans based there!!! Think general aviation.
Steve
Port St. Lucie, FL
772-475-5556
Sent from my Treo 600
jjessen
Posted: Thu Apr 27, 2006 12:45 pm Post subject: Autogas for 540 |
Fellow 4 doors down from me with a couple Taylor Craft has a fuel tank on a
trailer. Seems to work well for him. Other than fuel in the hanger, always
a hazard, not sure what the drawback would be?
Kellym
Posted: Thu Apr 27, 2006 12:47 pm Post subject: Autogas for 540 |
Unless you are attempting to keep the engine type certificated, STCs
wouldn't matter. However, materials compatibility is likely to be a big
issue. I know of a former Mooney owner who ran his O-360 on 91 octane
mogas. The fuel attacked to the polysulfide (PRC) in the fuel tanks
until it was a pink goo. I don't know if the polysulfides used today
are more resistant than what Mooney used in the late '60s, but I'd be
real concerned about affecting your tank sealant.
Certain low wing planes such as the Mooney were unable to get STCs
because of vapor issues, while others like the Cherokees had to change
fuel pumps.
Injection or carburetion makes little difference. Compression ratio is
the issue, with 8.5 being about the limit for 91 octane, and probably
8.0 for 87 octane.
Quoting GRANSCOTT(at)aol.com:
| Quote: | I get to fly behind the IO 540 in a C 182 going slowly and using a good
105kts..I
for fuel
make sure all
materials
Patrick
KCHD |
ericmpmail-rv10(at)yahoo. Guest
Posted: Thu Apr 27, 2006 1:44 pm Post subject: Autogas for 540 |
ECi Titan IO-540 kit engine (~ 2007?) is supposed to
be autofuel capable. This is partly because they are
using a fuel spider with fixed orifice and not a fuel
servo with some autogas sensitive components. Still
they rec 100LL initial for valves. Note this system
requires a return fuel line. I have built these
fittings into my tanks just in case. Part of reason
for return line is to return any vapor to tank.
Autogas and ethanol autogas in particular has lower
vapor pressure. Ethanol is also a good solvent for
lots of things....
Deltahawk claims they sold out 2005 and 2006
production runs but I have never seen a builder site
which makes me wonder if they really have that many
out there. I saw one article that 2005 run was only
two engines.
A number of builders are looking at rotary engines as
well.
Eric
Posted: Thu Apr 27, 2006 1:56 pm Post subject: Autogas for 540 |
In a message dated 4/27/06 5:52:46 P.M. Eastern Daylight Time, ericmpmail-rv10(at)yahoo.com writes:
| Quote: | Deltahawk claims they sold out 2005 and 2006
out there. |
I know the person that's #20 on the list has yet to smell diesel in the morning...promised for over a year ago...hope they make it...
P
