Roger.Mills(at)btinternet Guest
Posted: Mon Jul 12, 2010 2:13 am Post subject: Fuel Flow Problems |
Mike Gamble wrote:
Can anyone confirm the flow rate expected with no pressure applied?
Have I got myself a duff pump?
I=92m ready to get the engine fired up when this is sorted so any help
would
be appreciated.
G-CFMP”
Mike,
I managed to conduct some tests on Saturday and the results are (electric pump only):
Max pressure with no flow = 4psi
Maximum flow unrestricted ((at) entrance to mechanical pump and also last carburettor) = 90 l/h
Flow at 2.2 psi = 50.2 l/h.
It looks as if you've either a constriction/obstruction or a faulty electric pump.
It seems worth trying to measure output from pump outlet then progressing along the line maybe?
Hope this helps
Best Regards
Roger Mills
G-BVUV
G-BVUV
