johnwigney(at)windstream. Guest
Posted: Sun Jul 25, 2010 11:05 am Post subject: Europa-List Digest: 1 Msgs - 07/24/10 |
Hi Will,
I really have no idea if Decalin is approved by Rotax.. It never
occurred to me to inquire. Initially, I used 'TCP' which is the Alcor
product containing the active chemical, tri cresyl phosphate. 'TCP' was
available earlier and was used extensively by general aviation. This was
a certified product but has now been taken off the market. My
understanding is that the solvent carrier on this product was toxic if a
container leaked during flight.
"Decalin RunUp" uses a different formulation which is not volatile. See
http://www.decalinchemicals.com/fueladditive.html In any event, do read
the MSDS information. I do know that I never get any lead fouling on my
plugs and the lead appears to be scavenged well by my semi-synthetic oil
(Valvoline Durablend 10W-40) which is approved by Rotax. Since I have
always used this type of product, I have no comparative information.
Cheers, John
John
| Quote: | From: William Daniell <wdaniell(at)etb.net.co>
Subject: Re: Re : Travel Tool Kit
John
is decalin approved by rotax? Are there any alternatives? I use 100LL
all the time as well.
Will
John Wigney wrote:
Hi Troy,
Glad to hear that things are going well. My monowheel check list
includes the following:-
* Multi tip screwdriver
* Inexpensive metric and inch sockets and ratchet handle (e.g.
Harbor Freight supply)
* Spark plug wrench
* Metric Allen wrenches
* Small adjustable wrench
* Bag with common sizes of washers, bolts, screws, nuts, etc.
* Needle nose pliers.
* Tape & scissors.
* 1 quart oil
* Small bottle of NPG+ coolant
* Spark plugs
* Decalin fuel additive -
http://www.aircraftspruce.com/catalog/appages/Decalin.php (I
always use 100LL)
* Tow line for the tailwheel
* Tie downs
* Rotax voltage regulator (~200 hours life at best?)
* Jacking block
* Spare inner tube - Wicks Aircraft item # TB-MTAT8X6, this fits
8.00-6 & 7.00-6 tires. My tire is a 7.00-6, 6 ply.
I hope you can drag your plane into the air when you put it all on
board. Just kidding - never a problem.
Cheers, John
N262WF
Mooresville, North Carolina
