coop85(at)bellsouth.net Guest
Posted: Fri Apr 28, 2006 6:14 pm Post subject: Paint Guns |
I'm sure this'll create some discussion, but I was wondering what (besides
hundreds of $s) is the real difference in HVLP guns on the market. The SATA
seems very popular, and I know you get what you pay for, but exactly how is
it different than the $100 HVLP guns that look similar from a distance at
the auto parts store or Lowe's?
Thanks, and sorry if it's deemed a stupid question.
Marcus
40286 - stuck on wiring
johnwcox(at)pacificnw.com Guest
Posted: Fri Apr 28, 2006 9:33 pm Post subject: Paint Guns |
The biggest difference is in the precision of the air metering
circuitry, spring tensions and quality of adjustment in the spray
pattern. The differences do not really show themselves until cleanup
and adjustment after exposure to chemicals and paint materials. I have
some guns that look battle wary yet throw a perfect pattern after 30
years and I have some Chinese made which look gorgeous after 30 days and
lay an atrocious pattern.
The ability to lay a uniform line with no edge fade or heavier
application of topcoat is not visual by looking at the gun but rather
the applied paint on the job. The pleasure of pulling a trigger for a
12 hour episode versus blisters after two is a strange measure of
difference.
John $00.02
Posted: Sat Apr 29, 2006 3:52 am Post subject: Paint Guns |
Thanks John, good info. It sounds like you have quite a bit of experience,
do you also favor the SATA guns or do you prefer something else?
Marcus
bgill1(at)charter.net Guest
Posted: Sat Apr 29, 2006 4:25 pm Post subject: Paint Guns |
Marcus:
I have a SATA that I bought sometime back. If you wanted to give one a
shot "pun intended" or use it in the meantime you are welcome to it. I
am just getting ready to install the gear then engine then... and don't
see needing it for some time. May give us a reason to get together and
compare work.
Byron
(up in Douglas)
