Dick Maddux
Posted: Fri Aug 13, 2010 3:53 am Post subject: Engine roughnessEngine roughness |
Hugh,
I had pretty much the same thing happen on my Kitfox with the older mid 90's engine. The engine would quit on one" mag " After a lot of wire switching,etc it ended up being a broken wire.
Check the red power wires to the A and B modules. (or whichever doesn't work) The way I did it was to get an ohmmeter and but one lead to a ground on the engine (engine is NOT running by the way) then get a sewing pin and work your way down the wire from the connection at the modules. Punch thru the plastic sheilding of the small red wire with the pin to make sure you have continuity in the wire.Do this about every couple of inches or so all the way to the back of the engine I would be willing to bet you will find a break in the underlying wire and it is just barely touching at the broken end thus causing the module to be intermittently powered.That was the case with mine AND the break was in a straight wire run making it totally invisable from the surface . I found the internal wire break just a few inches from the module connection. I cut the wire,spliced it ,and am now back in business !
I hope that is your problem
Dick Maddux
912 UL
Milton,Fl
Dick Maddux
Posted: Fri Aug 13, 2010 3:56 am Post subject: Engine roughnessEngine roughness |
AH nuts! I wrote so fast on the reply trying to help Hugh, I forgot to use spell check! Am somewhat embarrassed. I can fly airplanes but can't spell worth a flip !!!
Dick Maddux
flyadive(at)gmail.com Guest
Posted: Fri Aug 13, 2010 4:42 am Post subject: Engine roughnessEngine roughness |
Dick:
What caused the wire to go intermittent in the first place?
Any ideas?
Barry
On Fri, Aug 13, 2010 at 7:52 AM, <Catz631(at)aol.com (Catz631(at)aol.com)> wrote:
[quote] Hugh,
Dick Maddux
912 UL
Milton,Fl
ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
ttp://forums.matronics.com
jonathan(at)entry.co.za Guest
Posted: Fri Aug 13, 2010 4:55 am Post subject: Engine roughnessEngine roughness |
I have just had this exact problem, the red wire was broken 10mm away from the plug! (Found the problem using the pin and Ohm Meter method)
I then bypassed the plug, with a new piece of wire, left the second ignition unchanged.
Flew for 2 Hours, to discover that the second ignition, now had a broken wire! About 15mm from the plug!
In both cases the wire had broken INSIDE the plastic insulation!
Please note that I did NOT install any of these wires, this is as installed by ROTAX.
How can such an expensive engine have such crappy wire!
Jonathan
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of FLYaDIVE
Sent: 13 August 2010 02:43 PM
To: rotaxengines-list(at)matronics.com
Subject: Re: Re: Engine roughnessEngine roughness
Dick:
Any ideas?
Barry
Hugh,
Dick Maddux
912 UL
Milton,Fl
| Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-Listttp://forums.matronics.com_blank">http://www.matronics.com/contribution |
| Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List | 0 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List | 1 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List | 2 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List | 3 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List | 4 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List | 5 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List | 6 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List | 7 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List | 8 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List | 901
hgmckay
Posted: Fri Aug 13, 2010 5:43 am Post subject: Engine roughnessEngine roughness |
Jonathan,
What "plug" are you referring to? Where is it located?
Hugh McKay
Sent: Friday, August 13, 2010 8:54 AM
To: rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com)
Subject: RE: Re: Engine roughnessEngine roughness
Jonathan
Dick:
Any ideas?
Barry
Hugh,
Dick Maddux
912 UL
Milton,Fl
0123456789 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List | 0 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List | 1 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List | 2 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List | 3 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List | 4 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List | 5
| Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List | 6 [quote][b]
Posted: Fri Aug 13, 2010 8:30 am Post subject: Engine roughnessEngine roughness |
There are two electronic modules, on top of the motor, marked A and B, these modules each have two plugs attached to them, one 4 Way and one 6Way
The 6Way plug connects, mostly to the Coils (HT Side), but one of the connectors attaches to a red wire, that is from the exciter coil, mounted on the back of the motor, where the pickup sensors are mounted.
The 4way connector is for the pickups at the back of the motor.
These two red wire comes from the back of the motor, and are shrouded in metal braid, which stops just before they plu into the 6way connector.
It is just before the 6way connector, that the wires break inside the insulation.
So all I had to do, was find the end of the Red wire(s) that still worked, bypass the 6way connector, and wire it straight into the respective modules.
Hope this helps
Jonathan
Dick Maddux
Posted: Sat Aug 14, 2010 6:12 am Post subject: Engine roughnessEngine roughness |
Dick:
Any ideas?
Barry
Johnathan and Berry
When I first attendend Lockwood's 912 engine course,Dean(the instructor) mentioned that the most likely problems you will find during troubleshooting ignition problems is, broken wires under the sheilding. As to how it happens,I really don't know but I would guess it is vibration. What happens if you bend a paper clip many times ? Even though the wire in question is braided wire,that is what happens. The shielding can take more bending prior to breakage so therefore,you don't see the break in the underlying wire.
That was the case with my engine and I suspect it will happen again.
Dick Maddux
912UL
Dick Maddux
Posted: Sat Aug 14, 2010 6:34 am Post subject: Engine roughnessEngine roughness |
Hugh,
Something else you might try is switching wires from one module to the other and see if the problem follows.
Dick Maddux
Milton Fl
