lsbrv7a(at)yahoo.com Guest
Posted: Mon May 01, 2006 5:36 am Post subject: Electric trim rigging |
I have found the documentation on rigging the electrioc rudder trim thin. Are there any guidelines for a apoximate length for the trreadded rod? Is the servo in the retracted position? What is the normal angle of the trim tab at the servo retracted position? What is the stroke of the servo? Wiring diragram?
Sherman Butler
RV-7a Wings
Idaho Falls
New Yahoo! Messenger with Voice. Call regular phones from your PC and save big.
dan(at)rvproject.com Guest
Posted: Mon May 01, 2006 6:15 am Post subject: Electric trim rigging |
What I did is retract the servo arm fully...mark that location on the arm
(just trace a line on the arm up against the servo body). Then extend the
arm fully. Mark that location on the arm. Measure halfway and mark that
line on the arm. Retract the servo until the halfway line is on the body of
the servo. The arm is now exactly in the middle of its range. Now rig the
pushrod so that the trim tab is in trail with the elevator.
That is how I rigged mine (RV-7), and I haven't had any problems in nearly
900 hours. No binding at either end of full travel. My 2 cents is to start
there, and you can always tweak it one way or another after you fly to bias
the range up or down.
)_( Dan
RV-7 N714D (882 hours)
http://www.rvproject.com
Posted: Mon May 01, 2006 7:17 am Post subject: Electric trim rigging |
Thanks Dan.
Did you pull the servo manually or power it electricly?
Sherman Butler
RV-7a Wings
Idaho Falls
Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2/min or less.
Posted: Mon May 01, 2006 7:53 am Post subject: Electric trim rigging |
| Quote: | Did you pull the servo manually or power it electricly?
Believe it or not I used a 9V battery at the time. Didn't have my 12V handy
and the little 9V worked just fine.
)_( Dan
RV-7 N714D
retasker(at)optonline.net Guest
Posted: Mon May 01, 2006 8:04 am Post subject: Electric trim rigging |
You MUST power it to move it. If you pull it you will likely break some
gear teeth!
Dick Tasker
Sherman Butler wrote:
Thanks Dan.
Sherman Butler
RV-7a Wings
Idaho Falls
mark(at)macomb.com Guest
Posted: Mon May 01, 2006 8:24 am Post subject: Electric trim rigging |
We used a battery from a Makita 9.6 volt cordless drill. We just touched
the leads to the contacts on the battery. Reverse the leads to reverse
the direction of travel I believe.
Mark
Richard Tasker wrote:
gear teeth!
Dick Tasker
> Thanks Dan.
