don.wentz(at)intel.com Guest
Posted: Mon May 01, 2006 8:43 am Post subject: Brake Discs |
Anyone know a Cleveland or Rapco part number for the discs on an RV-6?
Dw
RV-6 925hrs
ronlee(at)pcisys.net Guest
Posted: Mon May 01, 2006 9:25 am Post subject: Brake Discs |
The ones I use on my RV6A Sissy plane are RA66-106
but get a confirming email from someone else.
Ron Lee
| Quote: | Anyone know a Cleveland or Rapco part number for the discs on an RV-6?
Dw
RV-6 925hrs
chaztuna(at)adelphia.net Guest
Posted: Mon May 01, 2006 9:28 am Post subject: Brake Discs |
Don,
The Cleveland number is 164-01700. If you'd like to upgrade your brakes a bit, you can order a pair of 164-0990 discs. These are thicker than the stock units and will require that you make a spacer plate to be installed between the halves of your brake calipers. The spacer is to compensate for the additional thickness of these rotors. ACS and Wicks sell an "upgrade" kit for RV brakes which uses these rotors. They get $300 for the kit, which contains two 164-09900 rotors, two caliper spacers and 4 slightly longer caliper bolts. You can save money on the upgrade by making the spacers yourself and just buying the bolts.
FYI the "upgrade" discs are slightly LESS expensive than the stock rotors. Go figure!
Charlie Kuss
---- "Wentz wrote:
Dw
RV-6 925hrs
