inverteddecathlon(at)hotm Guest
Posted: Mon May 01, 2006 7:00 pm Post subject: rocket manuevers |
Could anyone tell me what aerobatic manuevers are permitted in a Rocket ?
I'm told the prop
extension puts excessive force on the crank and wish to know what exactly
you can and cannot
perform without damaging the engine.
Thanks- Craig
| | - The Matronics Rocket-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
nwinterest(at)yahoo.com Guest
Posted: Mon May 01, 2006 7:49 pm Post subject: rocket manuevers |
It depends on your prop, engine mounts and type of maneuvers. Any "gentleman" aerobatics are fine; These include rolls, loops, cuban eights, inverted flight (with appropriate system). If you have a metal prop and you are doing radical snap rolls or abrupt maneuvers, you might bend the shaft. If you have a composite prop, you can get away with more radical stuff; the prop will absorb some of that energy and not transmit it to the shaft/bearings. But, the aircraft has limits too. It isn't an unlimited type of aircraft. It is build, more or less, for basic aerobatics...maybe a step more.
-Good luck,
Matt
I'm told the prop
you can and cannot
Thanks- Craig
New Yahoo! Messenger with Voice. Call regular phones from your PC and save big.
Jim Anglin
Joined: 10 Jan 2006 Posts: 47 Location: Independence, OR (7S5 Airpark)
Posted: Tue May 02, 2006 7:24 am Post subject: rocket manuevers |
I have never seen an approved list of maneuvers published for any of the =
RV series including the HR II and F 1. All planes are limitied by the =
published airframe G force numbers and any equipment that is installed. =
In the case of the prop most are using on Rockets, the M2YR hub, we are =
limited to 3.8 Gs. There are variables that I am sure someone will =
point out but this is my controlling number. At 62 yrs. and 30 pounds =
overweight I am not interested in unlimited aerobatics, or even =
sportsman for that matter - an occassional roll or loop and I'm done.
Jim Anglin
HR II N144HR
DO NOT ARCHIVE
_________________ Jim Anglin
HR II N144HR |
