n61kf
Joined: 27 Aug 2006 Posts: 23 Location: Waynesville Ohio
Posted: Fri Oct 01, 2010 4:49 pm Post subject: 912 mid range power problem |
I recently started having a problem with the 912ul in my Kitfox IV. I noticed when reducing power in the pattern it would start running rough at about 4000 rpm, but then smooth out as I reduced power further.
On the ground I did a run up check, and found it ran normal from idle to 3000 rpm, but once reaching 3000 rpm it would just fall on it face, and run extremely rough. If I advance the throttle quickly it will make it through the rough range ( 3000 rpm to 4000 rpm) and run normally above 4000 rpm. This sounds to me most likely a carburetor problem. Have any of you run into this , and what was the fix?
Keith Schneider
KitfoxIV 912ul 200 Hrs
Waynesville , Ohio
_________________ Keith Schneider
Red Stewart Airfield
Waynesville Ohio
KF IV 912ul |
pchristensen10(at)austin. Guest
Posted: Sat Oct 02, 2010 8:26 am Post subject: 912 mid range power problem |
My 912 does the same thing. Carb heat smooths it out at all the mid
ranges.
Pete
Kitfox III, SN1000, 912
Leander, TX
On 10/1/2010 7:49 PM, n61kf wrote:
Keith Schneider
Waynesville , Ohio
Keith Schneider
Waynesville Ohio
KF IV 912ul
http://forums.matronics.com/viewtopic.php?p=314372#314372
propellerdesign(at)tele2. Guest
Posted: Sat Oct 02, 2010 9:55 am Post subject: 912 mid range power problem |
If carb heat smooth out the rough running, it means the mixture is a bit to
lean at mid range, hot air is less dense, making the mixture more rich.
Jan
Posted: Sat Oct 02, 2010 12:53 pm Post subject: 912 mid range power problem |
See it works.
Pete
On 10/2/2010 12:53 PM, JC Propeller Design wrote:
<propellerdesign(at)tele2.se>
bit to lean at mid range, hot air is less dense, making the mixture
more rich.
Jan
kerrjohna(at)comcast.net Guest
Posted: Sat Oct 02, 2010 2:07 pm Post subject: 912 mid range power problem |
One possible solution is to lower the circlips on the needle valve thereby raising them for slight richer mid range.Another approach is to change out the main jets to slightly larger which will richen the mixture at mid and upper range. Fly at 5000, ease out the enrichener watching rpm closely. If you get a slight increase in rpm this is the preferred approach, If you lose rpm you will be better served with the first solution.
John Kerr
Classic IV, 912, 800+ hours, loving it.
n61kf
Posted: Mon Oct 04, 2010 1:44 pm Post subject: Re: 912 mid range power problem |
Well, moving the needles up one notch seems to be the answer. It runs much smoother from idle up to full power now. At least on the ground. Tomorrow I will sync the carbs , put on the cowl, and go fly. After a few hours I will check the plugs for color, to see if I have gone too rich.
Thanks all for the advice.
Keith
Waynesville Ohio
KF IV 912ul |
Pat Reilly
Posted: Mon Oct 04, 2010 3:06 pm Post subject: 912 mid range power problem |
Keith, Moving the needle clips "up" drops the needle farther into the jet and makes your midrange leaner, not richer.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Mon, Oct 4, 2010 at 4:44 PM, n61kf <bkls1(at)earthlink.net (bkls1(at)earthlink.net)> wrote:
| Quote: | --> Kitfox-List message posted by: "n61kf" <bkls1(at)earthlink.net (bkls1(at)earthlink.net)>
Keith
Keith Schneider
Waynesville Ohio
KF IV 912ul
http://forums.matronics.com/viewtopic.php?p=314680#314680
ist Un/Subscription,
www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Lynn Matteson
Posted: Tue Oct 05, 2010 2:26 am Post subject: 912 mid range power problem |
Give him a break, Pat, he's from Ohio! (ducking.....) : )
Hey, Keith, did you go to MERFI this year?
Lynn Matteson
Jabiru 2200, #2062
Sensenich 62"x46" Wood (summer)
Rotec TBI-40 injection
Status: flying...1054 hrs (since 3-27-2006)
On Oct 4, 2010, at 7:03 PM, Patrick Reilly wrote:
| Quote: | Keith, Moving the needle clips "up" drops the needle farther into
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
Keith
Keith Schneider
Waynesville Ohio
KF IV 912ul
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
