javiercarrascob
Posted: Wed Oct 06, 2010 5:00 pm Post subject: TITUS at Titusville, FL TICO Airshow |
Hi Mark!
Hope you are doing great!
Hey I got the Spakplug kit from Dennis Savarece and the difference is just unbelievable!
Hey are you using the Marvel Mystery Oil?
If so in what proportion?
And do you add it everytime you put gas? or how often?
Regards, Javier
--- On Sun, 3/14/10, Mark Sorenson <captainsorenson(at)hotmail.com> wrote:
Quote: |
From: Mark Sorenson <captainsorenson(at)hotmail.com>
Subject: TITUS at Titusville, FL TICO Airshow
To: "Mark Sorenson" <captainsorenson(at)hotmail.com>
Date: Sunday, March 14, 2010, 7:43 AM
Sorry about the previous misfire with no photo attached.
This was captured yesterday at the TICO Airshow, in Titusville, FL. Other than having to deal with winds up to 30 mph it was a grrrrrrrrrreat day among grrrrrrrrrrreat people.
Best regards,
Mark Sorenson
678-GO-FLY-HI
www.tigerairshows.com
Hotmail: Trusted email with powerful SPAM protGBL/go/210850553/direct/01/">Sign up now.
Posted: Wed Oct 06, 2010 5:06 pm Post subject: TITUS at Titusville, FL TICO Airshow |
Thanks for the kind words about the kit, Javier.
Dennis Savarese
javiercarrascob
Posted: Wed Oct 06, 2010 5:58 pm Post subject: TITUS at Titusville, FL TICO Airshow |
Hi Dennis, I was writing you a longer thank you note, actually!
It took Sergey Boriak and me about 5 hours to get the yak ready for start, 3 of which were just tearing down the old harness!
The first start was just increadebly satisfactory, it took the prop about one swing and the engine was running smoother than ever.
I went and tested the mags at altitude and there was no loss of power %, I kept running for a couple of minutes each mag.
It was money very well spent, and Sergey mentored me in many maintenance tips!
Thank you
--- On Wed, 10/6/10, A. Dennis Savarese <dsavarese0812(at)bellsouth.net> wrote:
From: A. Dennis Savarese <dsavarese0812(at)bellsouth.net>
Subject: Re: TITUS at Titusville, FL TICO Airshow
To: yak-list(at)matronics.com
Date: Wednesday, October 6, 2010, 9:03 PM
Dennis Savarese
netmaster15(at)juno.com Guest
Posted: Wed Oct 06, 2010 8:13 pm Post subject: TITUS at Titusville, FL TICO Airshow |
Javier, Please provide me with a contact-phone number -if possible for Sergey Boriak. Thankyou CLIFF
Posted: Thu Oct 07, 2010 9:59 am Post subject: TITUS at Titusville, FL TICO Airshow |
Hello Javier,
Glad to hear you are happy with the ignition upgrade kit from Dennis. I have been involved with that mod on several aircraft and in each case, the improvement has been very noticable, especially at idle.
Yes, I do use MMO... but clearly I am no expert in it's use. I am one of these stupid people that think: "if a little bit is good, then a lot is even better!". That is not an especially "informed or wise" point of view, but you asked, so I am admitting it!
My YAK-50 holds about 32 gallons. I put about 1/2 quart or more in for a full tank. In some cases, I've put as much as a full quart in, but that is not common and I usually have done that just because I did not want to carry an open container around in the aircraft so I just poured it all in. Probably not too smart. CLEARLY this is over the recommended amount... but I really don't think it has hurt anything since I have been doing it for almost 10 years now. So, I suppose the answer to your question is to simply run the recommended amount but if you go a little over ... it doesn't seem to hurt anything. This is subject to change by someone who knows more than me about the issue!
As for oil.... I use MMO as a kind of "cleaner". When I get ready to change the oil in my engine, I pour in TWO QUARTS of MMO and then go for a short flight and run the engine hard. I then come back and immediately drain it all out. Again, this might not be a great recommendation, but it is what I do.
In short, the subject of MMO, how much to use, when to use it, and whether it is even any good in the first place.... is something that has been a hot topic on this list server for quite a number of years. In no way would I dare to recommend a certain amount, or even claim that the stuff really works! I use it because it does not seem to hurt anything, and APPEARS to have helped me regarding valve leading issues.
Mark
Sent: Wed 10/6/2010 8:57 PM
To: Mark Sorenson; yak-list(at)matronics.com
Hi Mark!
Regards, Javier
Best regards,
Mark Sorenson
678-GO-FLY-HI
et=_blank>http://www.matronics.com/Navigator?Yak-List
p://forums.matronics.com/
javiercarrascob
Posted: Thu Oct 07, 2010 7:13 pm Post subject: TITUS at Titusville, FL TICO Airshow |
Sure 703 216 0991
--- On Thu, 10/7/10, netmaster15(at)juno.com <netmaster15(at)juno.com> wrote:
From: netmaster15(at)juno.com <netmaster15(at)juno.com>
Date: Thursday, October 7, 2010, 12:07 AM
rick(at)rvairshows.com Guest
Posted: Fri Oct 08, 2010 5:22 am Post subject: TITUS at Titusville, FL TICO Airshow |
I need information about MMO. Is there any aviation engine testing available with this additive? Are aircraft owners that are using this oil actually trusting anecdotal evidence or it's performance in non-aviation engines? How does this additive compare to CamGuard? The engine teardown testing by Monte Barrett and others completely reinforces CamGuard claims, as has many independent, scientifically performed studies. A sample size of one is statistically useless in proving anything. Wait a minute, I kiss my Sukhoi after every flight and it is running better than ever. Anybody else care to try that?Rick Volker
On Oct 7, 2010, at 1:55 PM, Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E wrote:
[quote] Hello Javier,
Mark
To: Mark Sorenson; yak-list(at)matronics.com (yak-list(at)matronics.com)
Hi Mark!
Regards, Javier
--- On Sun, 3/14/10, Mark Sorenson <captainsorenson(at)hotmail.com (captainsorenson(at)hotmail.com)> wrote:
Quote: |
From: Mark Sorenson <captainsorenson(at)hotmail.com (captainsorenson(at)hotmail.com)>
To: "Mark Sorenson" <captainsorenson(at)hotmail.com (captainsorenson(at)hotmail.com)>
Best regards,
Mark Sorenson
678-GO-FLY-HI
