Posted: Thu Oct 14, 2010 2:47 pm Post subject: Painting screws and small parts - what to stick them in - f |
I use a piece of cardboard to hold PK screws (like wood screws) and a
piece of Masonite with the holes in it .... like pegboard.
Some foams aren't compatible with paint so test before you try and spray
screws.
Linn
On 10/14/2010 6:28 PM, Bill Watson wrote:
I remember seeing someone use foam or some other material to stick
screws into for painting. I have some blue foam that looks like it
will spray debris all over the place.
Has anyone used formed successfully? What kind did you use.
Bill "fume breathing.... not" Watson
Posted: Thu Oct 14, 2010 3:37 pm Post subject: Painting screws and small parts - what to stick them in - f |
Poke some holes into a cardboard box with an awl and press the screws
into the holes. Aircraft Spruce boxes seem to work particularly well...
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Thu, Oct 14, 2010 at 3:28 PM, Bill Watson <Mauledriver(at)nc.rr.com> wrote:
I remember seeing someone use foam or some other material to stick screws
into for painting. I have some blue foam that looks like it will spray
