info(at)jabiru.cl Guest
Posted: Wed Oct 20, 2010 5:39 pm Post subject: low compression on Jabiru engine using AVGAS |
Hi group, I have 3 engines (3 different owners in different cities) that are running on avgas 100/130 in Chile, that after 80 hours are with low compression on 2 or more cylinders. Have some of you any experience with same issue? 2 of these engines are flying in J450 and J430 and one of them is mounted in a Jabiru UL (2200).
Please any commends will be appreciated,
Christian
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
flyadive(at)gmail.com Guest
Posted: Wed Oct 20, 2010 7:09 pm Post subject: low compression on Jabiru engine using AVGAS |
Christian:
There is a VERY good chance you are experiencing the same problems MANY engines here in the USA are experiencing while running on 100LL. 100LL is really not Low Lead at all. It is four times the lead as the old AvGas 80.
Since you are having low compression I would bet that they are experiencing lead/coke build up in the valve stems.
If the build up goes untreated the valve will stick in the down (open) position and if the valve - cylinder clearance is an interference fit they will be spitting out valve parts. AND even if it is not an interference fit, the compression will go to zero and still again they will be looking for an emergency field and new engine parts.
The options are:
Use TCP in the fuel to reduce lead build up
LEAN AGGRESSIVELY - ALL THE TIMES -- Even when taxing.
Use AUTO - MoGas or a mixture of MoGas & AvGas. Just keep the octane where needed.
1 hour flight before every oil change put in one quart of MMO (Marvell Mystery Oil) - This helps clean the build up.
Now, these suggestion come with the limited information you gave. We don't know how the engines are being run.
The time between oil changes.
The type of oil being used.
The quality of the gas and at least a dozen more items.
Since you identified that the engines have low compression - Have you identified where they are leaking from?
Valves or Rings?
Any gasket leaks?
Fill in the blanks on the above questions and I'll try to diagnose.
GOOD LUCK,
Barry
On Wed, Oct 20, 2010 at 9:36 PM, Jabiru Chile <info(at)jabiru.cl (info(at)jabiru.cl)> wrote:
Christian
plus2s
Posted: Thu Oct 21, 2010 1:37 am Post subject: low compression on Jabiru engine using AVGAS |
Hi Christian
We have found that the high lead content of 100/130 can cause the top ring to get tight in the ring groove. There is some interesting facts re the different fuels in the January 2010 Jabba Chat on the Jabiru Au web site. It is also important to make sure the engine is not running lean. ie has the latest recommended jetting. Of course that can vary if the engines aren't in Jabiru airframes. It is also possible to get lead deposits stuck under a valve.
Will be interested to see what you find.
Keith
--- On Thu, 21/10/10, Jabiru Chile <info(at)jabiru.cl> wrote:
Subject: low compression on Jabiru engine using AVGAS
To: jabiruengine-list(at)matronics.com
Date: Thursday, 21, October, 2010, 2:36 PM
Hi group, I have 3 engines (3 different owners in different cities) that are running on avgas 100/130 in Chile , that after 80 hours are with low compression on 2 or more cylinders. Have some of you any experience with same issue? 2 of these engines are flying in J450 and J430 and one of them is mounted in a Jabiru UL (2200).
Christian
| Quote: | f="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matro="nofollow" target="_blank" href="http://forums.matronics.com">http://www.matronics.com/contribution">http://www.matronics.com/contribution============
| [quote][b]
BobsV35B(at)aol.com Guest
Posted: Thu Oct 21, 2010 6:24 am Post subject: low compression on Jabiru engine using AVGAS |
Good Morning Keith,
You wrote: "It is also important to make sure the engine is not running lean"
Could you expand on this statement a bit? At lower power settings, lean is the best place to be and at high power settings it is not. In either case, lean is always relative and it should be on the lean side or on the rich side relative to some operating parameter.
Don't you agree?
Happy Skies,
Old Bob
In a message dated 10/21/2010 4:37:22 A.M. Central Daylight Time, kpickford(at)xtra.co.nz writes:
| Quote: | Hi Christian
Keith
Subject: JabiruEngine-List: low compression on Jabiru engine using AVGAS
Christian
List href="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-List
ms.matronics.com/">http://forums.matronics.com
Posted: Thu Oct 21, 2010 6:39 am Post subject: low compression on Jabiru engine using AVGAS |
Good Morning Barry,
The last time I flew down south of the border, 100/130 AVGAS was still the old mix and it had about three times the lead of 100LL. That means it has about twelve times the lead of the old 80 Octane AVGAS. Really bad stuff for a relatively low compression engine.
Could anyone tell us whether that is still the case?
Happy Skies,
Old Bob
In a message dated 10/20/2010 10:10:11 P.M. Central Daylight Time, flyadive(at)gmail.com writes:
| Quote: | Christian:
The options are:
Valves or Rings?
Any gasket leaks?
GOOD LUCK,
Barry
Christian
plus2s
Posted: Thu Oct 21, 2010 2:57 pm Post subject: low compression on Jabiru engine using AVGAS |
Hi Bob
we had a engine "Blow" at 500 hours that was running lean. An early hydraulic lifter 2200 engine.
Jabiru bought out a revised tuning (jetting) for them.
Keith
--- On Fri, 22/10/10, BobsV35B(at)aol.com <BobsV35B(at)aol.com> wrote:
| Quote: | From: BobsV35B(at)aol.com <BobsV35B(at)aol.com>
Subject: Re: low compression on Jabiru engine using AVGAS
Date: Friday, 22, October, 2010, 3:20 AM
Good Morning Keith,
lean"
the rich side
Don't you agree?
Happy Skies,
Old Bob
Daylight Time,
Hi Christian
tight in the ring
the latest
engines aren't in
valve.
find.
Keith
Subject: low
To:
2:36 PM
Hi group, I have 3
engines
running on avgas
one of them is
Please any
commends will
be appreciated,
Christianf="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matro="nofollow"
target="_blank"
List
Posted: Thu Oct 21, 2010 3:06 pm Post subject: low compression on Jabiru engine using AVGAS |
Thank you Barry,
Thank you for the info. The info I can share is:
Engine (J3300 in J450), about 80 hours since new, using AVGAS100/130 since first start in Chile, Oil used Shell aviation oil multigrade, Airplane build to Jabiru standards with no extras other that ones offered by Jabiru, Jabiru standard prop for this engine/airplane config., maintenance of engine according to engine manual (oil changes, spark replace, oil filter, etc). Leak are in two cylinders (more than others) and came from the exhaust valves, but these two low compression cylinders where checked and the inside of the cylinders looks not good with some scratches, probably done by the rest of lead/coke build up in the combustion chamber or in top of the pistons. Airplane is located 1000 km from Santiago and is flying by a Flying Club.
Engine (J3300 in J430), about 80 hours since the pilot report low compression 2 month ago. Same configuration than the above airplane, one owner, flying near Santiago, and the problem found was in the exhaust valves, but this airplane/engine have the economy tunning kit that Jabiru offers for this engines.
Engine (J2200 in Jabiru UL), after a change of engine in the airplane, due the original engine was from 1998 with 800 hours, was not worth to make an overhaul, so the owner opt to change engine for a new model with longer overhaul, hydraulic lifters, etc., but after about 70 hours and after a maintenance check the mechanic found that the engine was not running good and make a compression check. Same problem than above engines. Exhaust valves not sealing, and after a clean up, was again with normal compression and now the owner decide to use automobile gas 97 oct rating, unleaded.
I have also about 10 engines in Ultralight airplanes flying with automobile gas 97 oct, and some of them with more than 800 hours, with compressions like a new engine, so the AVGAS here in my conclusion is not the best for Jabiru engines.
Thank you all for your support and info.
Christian
De: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] En nombre de FLYaDIVE
Enviado el: Thursday, October 21, 2010 12:07 AM
Para: jabiruengine-list(at)matronics.com
Asunto: Re: low compression on Jabiru engine using AVGAS
Christian:
The options are:
Valves or Rings?
Any gasket leaks?
GOOD LUCK,
Barry
Christian
| Quote: | | http://www.matronics.com/Navigator?JabiruEngine-List | 0123456789
Posted: Thu Oct 21, 2010 4:45 pm Post subject: low compression on Jabiru engine using AVGAS |
Good Evening Keith,
I can understand that if it was running "Lean" when it should have been not running "Lean", but that still does not answer the question. Lean in relation to what?
And, at what power settings?
Makes a very big difference.
Happy Skies,
Old Bob
In a message dated 10/21/2010 5:57:40 P.M. Central Daylight Time, kpickford(at)xtra.co.nz writes:
| Quote: | --> JabiruEngine-List message posted by: Keith Pickford <kpickford(at)xtra.co.nz>
Hi Bob
Keith
Good Morning Keith,
lean"
the rich side
Don't you agree?
Happy Skies,
Old Bob
Kayberg(at)aol.com Guest
Posted: Fri Oct 22, 2010 7:08 am Post subject: low compression on Jabiru engine using AVGAS |
Barry,
Do you have significant experience with Jabiru engines? Your comments would indicate a background in other engines (Ly-Con) which are not the same as a Jabiru.
For example, the carbs are not leanable, nor is leaning suggested by Jabiru
Further, since the Jab engines have such a low oil volume, your Marvel Mystery Oil suggestion is not a good one, and might generate a whole other set of problems.
Doug Koenigsberg
In a message dated 10/20/2010 11:10:11 P.M. Eastern Daylight Time, flyadive(at)gmail.com writes:
| Quote: | Christian:
The options are:
Valves or Rings?
Any gasket leaks?
GOOD LUCK,
Barry
Posted: Fri Oct 22, 2010 7:48 am Post subject: low compression on Jabiru engine using AVGAS |
Good Morning Doug,
Your comment is correct as far as it goes.
However, you will note that Jabiru does suggest changing the jets and the metering rod to get the mixtures desired. The Bing Carburetor does automatically adjust the mixture due to changes in altitude, but the changes at high power and at cruise are made by changing the components in the carburetor to compensate for different RPM on various engine applications.
Christian's problem still may be heavily associated with the 100/130 fuel that is being used. 100/130 is NOT the same as 100LL. If the 100/130 AVGAS still has the composition that we in the USA had before 100LL came on the scene, he is getting an abominable amount of lead in the engine. If it is running rich at relatively low power settings (below seventy-five percent or so) lead will be built up on valve stems, spark plugs, and in the ring lands. No more lead should be used than is absolutely required for the compression being used.
Higher octane fuel does no good at all in an engine that does not have a compression ratio requiring it. Getting a high octane rating by using lots of lead is especially hard on the engine. The more modern USA standard 100 LL has a LOT less lead than does/did 100/130 AVGAS.
Not sure which is available where Christian operates, but lead is bad and should be avoided wherever possible.
While the fuel used at full takeoff power must be rich enough to have a suitable octane rating to avoid detonation at that power, no lead at all is needed at cruise power and operating on the lean side of best power for cruise is always the best for the engine provided that distribution is adequate.
Jabiru attempts to get a suitably rich mixture at takeoff power and a suitably lean mixture at cruise power by selecting appropriate fuel rods and suitable jetting. The Bing Carburetor works great when it is suitably set up. Personally, I would prefer to have manual mixture control, but I am horribly old fashioned. <G>
Happy Skies,
Old Bob
In a message dated 10/22/2010 10:09:01 A.M. Central Daylight Time, Kayberg(at)aol.com writes:
| Quote: | Barry,
Doug Koenigsberg
| Quote: | Christian:
The options are:
Valves or Rings?
Any gasket leaks?
GOOD LUCK,
Barry
Posted: Mon Oct 25, 2010 6:12 pm Post subject: low compression on Jabiru engine using AVGAS |
Thank you guys for the info and commends. I think the same way that the AVGAS here could be a problem. I’m still investigating the problem and if I find something interesting for you, I will post it in this forum again.
Thank you,
Christian
De: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] En nombre de BobsV35B(at)aol.com
Enviado el: Friday, October 22, 2010 12:45 PM
Good Morning Doug,
Happy Skies,
Old Bob
Barry,
Doug Koenigsberg
Christian:
The options are:
Valves or Rings?
Any gasket leaks?
GOOD LUCK,
Barry
| Quote: | | ====================================List href="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-List====================================ms.matronics.com/">http://forums.matronics.com====================================tp://www.matronics.com/contribution">http://www.matronics.com/contribution==================================== | | 0123456789 | Quote: | | ==================================== | 0 | Quote: | | ==================================== | 1 | Quote: | | ==================================== | 2 | Quote: | | ==================================== | 3 | Quote: | | ==================================== | 4 | Quote: | | ==================================== | 5 | Quote: | | ==================================== | 6 | Quote: | | ==================================== | 7 | Quote: | | ==================================== | 8 | Quote: | | ==================================== | 9
