john.marzulli(at)gmail.co Guest
dougsnash
Posted: Mon Oct 25, 2010 3:59 am Post subject: Flaperon limits? |
John, if I remember correctly the flapperon up/down deflections are 13 degrees. The flap deflection is supposed to be 15. This gives you a total of 28 down and 13 up.
But as I said, the above information is based on memory so double check before cutting aluminum.
Doug MacDonald
CH-701 C-GBQX
NW Ontario, Canada
--- On Sun, 10/24/10, John Marzulli <john.marzulli(at)gmail.com> wrote:
Subject: Flaperon limits?
Received: Sunday, October 24, 2010, 11:25 PM
I can't seem to find the flaperon deflections for my 701. I have the neutral position identified, but I am unsure how how far up and down from neutral the slots need to be cut.
John Marzulli
randy(at)rjhebertassoc.co Guest
Posted: Mon Oct 25, 2010 4:24 am Post subject: Flaperon limits? |
Aileron (flaperons) UP 13 +/- 1
Down 13 +/- 1
Flap Max 16 +/- 2
Elevator UP 32 to 35
Down 28 to 30
From the Construction manual
Randall J Hebert
N7701P
Plans Building
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of MacDonald Doug
Sent: Monday, October 25, 2010 6:55 AM
Subject: Re: Flaperon limits?
Doug MacDonald
CH-701 C-GBQX
NW Ontario, Canada
John Marzulli
| Quote: | | http://www.matronics.com/Navigator?Zenith701801-List | 0123456789
SABorns(at)aol.com Guest
Posted: Mon Oct 25, 2010 7:05 am Post subject: Flaperon limits? |
John,
This is the info you need.
D:\Photo Assembly Guides\Construction Manual\DEFLECTIONS.pdf
Steven Bornstein K8IDN
475 E. North Broadway
Columbus, Ohio 43214
614 263-5819
In a message dated 10/25/2010 12:32:50 A.M. Eastern Daylight Time, john.marzulli(at)gmail.com writes:
Posted: Mon Oct 25, 2010 7:06 am Post subject: Flaperon limits? |
614 263-5819
JohnDRead(at)aol.com Guest
Posted: Mon Oct 25, 2010 8:19 am Post subject: Flaperon limits? |
The flaps are designed to go down 15 degrees, Travels are on one of the drawings that shows all travels.
Regards, John
CH701 - Colorado - Jabiru 3300
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 10/24/2010 10:32:50 P.M. Mountain Daylight Time, john.marzulli(at)gmail.com writes:
