dons701
Posted: Sun Oct 24, 2010 2:35 pm Post subject: Thrust Centerline of the 2200A |
I recently noticed that the centerline of my Jabiru 2200A was pointing downward a degree or so, relative to the longitudinal centerline of my 701. I have ordered new rubber motor mounts from Jabiru USA as the existing mounts are showing some surface cracks and generally are sagging.
The question I have is what if any advantage would there be to shim the centerline of thrust to any angle other than parallel to the centerline of the plane as seen from the side view. When viewed from above I have the required 3 degrees, (23 mm measured at the back of the engine), of offset thrust to the passenger side. Just curious if anyone running the same combination might have experimented with the thrust centerline in any way. Pro's Con's ?/
Thanks....Don
_________________ Zenith 701 #76120
Jabiru 2200A #2456 95 hours
Sensenich Wood 64-PJ-36 Prop |
bobkat
Joined: 07 Sep 2008 Posts: 143 Location: Bismarck, ND
Posted: Sun Oct 24, 2010 7:25 pm Post subject: Thrust Centerline of the 2200A |
The engine mount fro my 701 looks "crooked" when you look along it with
reference to the airplane. I checked into it and its supposed to be that
way. It is built to counteract torque from the engine, and/or ?P factor or
whatever. But first time I noticed this I though the thing was made wrong!
If I remember, I think the engine mount pointed down a bit and maybe a hair
to the right?? Can't recall for sure.
Don't know about the Jabiru though, or whether messing with shims might do
more harm than good. When I called about my Rotax mount they said it was
designed especially for all the forces of the full throttle engine, and was
supposed to be that way.
Sent: Sunday, October 24, 2010 5:35 PM
To: <zenith701801-list(at)matronics.com>
Subject: Thrust Centerline of the 2200A
Pro's Con's ?/
Thanks....Don
Zenith 701 #76120
Jabiru 2200A #2456 67 hours
http://forums.matronics.com/viewtopic.php?p=316891#316891
n801bh(at)netzero.com Guest
Posted: Mon Oct 25, 2010 5:39 am Post subject: Thrust Centerline of the 2200A |
It is my opinion that Chris designs all his planes using a tried and true method. A simple way to counteract P force and to get the plane to fly decent he adds offset to the engine mounts.
Here is a link to the 801 thrust line drawing. I bet it is similar to all his designs, especially the 701.
http://www.zenithair.com/stolch801/data/thrust.pdf
Ben Haas
N801BH
www.haaspowerair.com
Geoff Heap
Joined: 12 Jan 2006 Posts: 266 Location: Lindenwold, New Jersey
Posted: Mon Oct 25, 2010 6:21 am Post subject: Re: Thrust Centerline of the 2200A |
Don. I agree the 3° to the right is normal. The 1° down...Never heard of it. Ive been on these Matronics lists for a long time........Geoff
_________________ Dual controls. Dynon 180. Icom 210 Garmin 296. Becker transponder. Sigtronics intercom. Electric flaperons. |
dons701
Posted: Mon Oct 25, 2010 7:08 am Post subject: Re: Thrust Centerline of the 2200A |
Thanks to all
I plan to purchase a digital protractor today to see how far nose down the engine is relative to the fuselage. Always wanted one those, now I have a good excuse. Thanks for the drawing Ben, interesting to see they allow a 5 degree tolerance + or -, that is surprising. One can only imagine how she would fly thrust up, or thrust downward 5 degrees.
Jabiru USA is out of rubber engine mounts and I will have to wait literally for a slow boat from Australia. My mounts are sagged a bit and a few are showing small surface cracks......Don
JohnDRead(at)aol.com Guest
Posted: Mon Oct 25, 2010 8:13 am Post subject: Thrust Centerline of the 2200A |
Down a degree is OK. I had to mess around with the washers between the mount rubber inserts.
Regards, John
CH701 - Colorado - Jabiru 3300
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 10/24/2010 4:40:40 P.M. Mountain Daylight Time, burdon1(at)comcast.net writes:
| Quote: | --> Zenith701801-List message posted by: "dons701" <burdon1(at)comcast.net>
Thanks....Don
Zenith 701 #76120
http://forums.matronics.com/viewtopic.php?p=316891#316891===============================================
_-= = Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
dons701
Posted: Mon Oct 25, 2010 10:23 am Post subject: Re: Thrust Centerline of the 2200A |
After removing the motor mount nuts and lifting the motor slightly, I took notice that the rubber mounts were permanently deformed downward where the engine frame tubes poke through. So, I sprayed some soapy water on the rubbers and rotated them half a turn then snugged everything up till the new rubbers come in. The engine is now 0 to 1/2 degree nose up relative to the fuselage centerline. P-factor angle was dead on. ...... Don
