zsmith3rd(at)earthlink.ne Guest
Posted: Fri May 05, 2006 8:40 am Post subject: 912 water temp probe? |
List,
Anyone installed an actual 'water temperature' sender on a 912 in the water circuit?
The two holes provided by Rotax for the CHT on cylinders 2 & 3 don't actually touch water.
Any advice from experienced 912 jocks?
Thanks!
Regards to all,
Zed/701/R912/90+%/etc/do not archive
cgalley(at)qcbc.org Guest
Posted: Fri May 05, 2006 1:13 pm Post subject: 912 water temp probe? |
The fact that there are not thru holes will not influence the temperature by
much if any. The big thing is that they won't leak when the probe fails.
Nor will the coolant corrode the probe.
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
A Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
thilo.kind(at)gmx.net Guest
Posted: Fri May 05, 2006 1:48 pm Post subject: 912 water temp probe? |
Hi Zed,
I have installed a water temp probe. In my CH601 HDS, I'm using an original
Rotax rad inside the cowling. Most of the plumbing is made from rubber
hoses, but one section is 2'' AL piping. On this section I had a small tube
welded on, at which end the probe is installed. Working okay so far (since 4
years). However, it's not really needed, since the CHT probes are
sufficient.
Best regards
Thilo Kind
