Zenith Bending Brake
bill_dom(at)yahoo.com
PostPosted: Sun May 07, 2006 4:23 pm    Post subject: Zenith Bending Brake Reply with quote
Ive built the 48 bending brake from the plans
provided by Zenith. The brake came out pretty well
aligned up to a
millimeter precision. The hinges where welded using a
jig that ensured accurate alignment and there is no
play in it. However, bend like the spar cap doublers
(48 .040) comes out slightly bowed. When placed over
a flat surface the center raise around 3 millimeters.
I takes almost no pressure to align it into place but
when release it spring back to its bowed form. Is
there anyone out there who have this brake and have
been able to get better bends?. Can I still use the
part?.
William Dominguez
Plansbuilt Zodiac 601XL
larry(at)macsmachine.com
PostPosted: Sun May 07, 2006 4:58 pm    Post subject: Zenith Bending Brake Reply with quote
William,
The bow you describe for the doublers is rather common, but not a problem
once you've interconnected it with ribs, spar and skins. You should be
able
to use the part without reservation if all other dimensions are met.
Larry McFarland at www.macsmachine.com
aligned up to a
part?.
William Dominguez
