pcondon(at)mitre.org Guest
				 Posted: Sat May 06, 2006 8:40 am    Post subject: Prop Governers |
				My -540-C4B5 has a 1/4 inch or so spacer between the case and the
 governor. Without this spacer, the drive gear preload would be amiss.
 Also, the gaskets need care when installing to get the proper ones due
 to oil hole alignment. I would recommend a prop shop rebuild the
 governor. There are oil orifices and passages within the governor and
 the repair facility can tweak the governor and "match" your speed
 (Rocket) and Prop. Also, the proper gaskets can be supplied by the
 repair facility...they know which ones to use on both sides of the
 spacer.......
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Rocket-List |
