Posted: Fri Dec 10, 2010 11:02 am Post subject: Fuel Tank Weight |
Does anybody have their fuel tank available to weigh? I am wondering the weight of just the fuel tank, empty, with all of the sealant and nothing else.
Thanks.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
pietflyr(at)bellsouth.net Guest
Posted: Fri Dec 10, 2010 12:31 pm Post subject: Fuel Tank Weight |
Mine are complete, but not yet installed on the wing.
One tank weighs (with fuel cap) 17.5 lbs (+/- .25 lbs). My bathroom scales
only go in increments of .5 lbs so if you need better accuracy someone else
will have to supply it.
Jack Phillips
#40610 (Wings)
Raleigh, NC
Posted: Fri Dec 10, 2010 12:52 pm Post subject: Fuel Tank Weight |
You are in luck. I just remove the right tank to do a flush and then let
fuel sit in it to check for weepage. Empty tank weight, with fuel cap and
fuel sender: 17.7 lbm.
Carl (still filling and sanding the cowl and plenum)
