GeoB
Posted: Wed Dec 29, 2010 2:23 am Post subject: Sonex or GP VW |
| Quote: | Direct drive Kolbs do not do well and have never performed well on any
model Kolb.
I hear you, but would like a few more details. I have been following this
thread because I have a Kolb FS-1. I read about the Kolb powered by the
Generac, and the struggles Mr. young had. He said his plane (FSII) weighed
in at 435 dry and empty. I *think* mine will come in between 280-300# with
Generac (if I go that way). I have been considering trying out the Generac
direct-drive on there.
| Quote: | When compared to an engine with a reduction drive, there is a marked
performance increase with reduction drives.
I understand that this will cost me performance. I am just wondering how
much. I can/probably will get a PSRU, but want to look at direct-drive
before giving up on it. Would any of you care to throw out some guesses as
to how it would perform? I weigh a lil more than 210# but getting lighter as
we speak.
| Quote: | As a direct drive Kolbster,I could not agree with you more.
G.Aman
Mr. Aman! What kind of setup do you have?
| Quote: | Faith is believing what you know ain't so - Mark Twain
Mark Twain had a lot of things right, but a man such as himself isn't
qualified to speak on 'faith'. He doesn't know diddly about it. But I
respect your right to quote him, and would fight to the death to protect my
right to needle you about it a lil bit.
"Faith is taking the first step even when you don't see the whole
staircase".
- Martin Luther King, Jr.
And I would add, "particularly when you know who built it"
GeoB
_________________ GeoB
"Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors" |
neilsenrm(at)gmail.com Guest
Posted: Wed Dec 29, 2010 8:09 am Post subject: Sonex or GP VW |
George
I don't think the direct drive Generac option is a good choice for at least two reasons. First, it doesn't sound like you will be happy with the performance if it will even fly.
Another reason is the ability of that engine to accept a direct drive prop. My experience with the VW conversion indicates that there was a long and checkered development process in getting a reliable engine. The first concern is a prop hub attachment. Does anyone make a prop hub for direct attachment to the Generac?
Next is how will the Generac handle the gyroscopic and harmonic loads of a direct drive prop? VWs had to change to forged crankshafts with a hardened key way and a custom deep drilled and taped prop mounting bolt hole to handle the harmonic loads and then they require only wood props. Also this is with a engine that has fairly even firing pulses. The Generac has two cylinders in a V configuration. This is not a good choice for driving a prop. I know Valley had to develop a custom one way slipping redrive to handle the Generac's nasty harmonics. To handle the gyroscopic loads most VW engines now use a custom main bearing machined into the prop end of the engine case. It is four or five times the surface area of the original. Oh yes and one final issue is the thrust loading on the crank.
Besides that no big deal go for it.
Again as always worth what you paid for it.
Rick Neilsen
1st Redrive VW powered MKIIIC
On Wed, Dec 29, 2010 at 5:15 AM, George Bearden <gab16(at)sbcglobal.net (gab16(at)sbcglobal.net)> wrote:
[quote]--> Kolb-List message posted by: "George Bearden" <gab16(at)sbcglobal.net (gab16(at)sbcglobal.net)>
model Kolb.
we speak.
G.Aman
staircase".
-Matt Dralle, Li - The Kolb-List Email Forum -
b-List" target="_blank">http://www.matronics.com/Navigator?Kolb-List< - MATRONICS WEB FORUMS -
= --> h
zeprep251(at)aol.com Guest
Posted: Wed Dec 29, 2010 10:04 am Post subject: Sonex or GP VW |
George,
Had a FS2 with 503 which of course is redrive equipped.I now fly a MK3C jabiru 2200a direct drive w/Sensenich wood prop.It is slower than a redrive mk3 912ul although both are 80 hp.I love this engine but it makes a lot of noise.My most desired setup would be Jabiru w/PSRU which Jabiru could do because the case is CNC milled from billet stock,they could put attach surfaces on the case easily IMHO.
G.Aman MK-3-C Jabiru 2200A Sensenich 600hrs
Posted: Wed Dec 29, 2010 7:35 pm Post subject: Sonex or GP VW |
One of the Generac's attractions for me is that it's designed from the start as an industrial, run all day at rated power, almost any kind of load type of engine. While the power pulses are uneven & may give a reduction drive fits, the engine & in particular the crank should handle almost anything short of a serious resonance issue. VW & other auto engines were never designed to take side loads on the end of the crank, but the Generac crank has a pulley mounted to it in many applications (exception would be direct drive generators).
I could be wrong, but I would think that a wood prop on a direct drive Generac would present less load than the crank sees while driving 4 feet of steel blades through ant hills, small logs, etc with the load transferred to the crank through a cantilevered pulley.
FWIW,
Charlie
On 12/29/2010 10:06 AM, Rick Neilsen wrote: [quote] George
Rick Neilsen
| Quote: | --> Kolb-List message posted by: "George Bearden" <gab16(at)sbcglobal.net (gab16(at)sbcglobal.net)>
model Kolb.
we speak.
> G.Aman
staircase".
Posted: Thu Dec 30, 2010 8:35 am Post subject: Sonex or GP VW |
Charlie/All
Ok.... Lets just assume for a moment that the Generac will handle the harmonic, gyroscopic, and thrust loads. The engine is designed as a industrial engine which is a good thing except for weight and power.
Valley Engineering souped up the Generac engine, lightened it a bit, added their reduction drive and put it on Jimmy Young's Kolb FS. Jimmy even had to opportunity to fly the plane with the engine installed and choose the best prop by flying a selection of props. With all that it was found to be inadequate for Jimmy. Imagine now that a stock Generac with a dirict drive prop is installed on what George feels is a much lighter FS. Lets also assume that George will get the prop selection perfect and will get conservatively as much as 80% of the thrust of a reduction drive Generec. Jimmy or anyone how well would the plane fly?
I'm not a engineer and I could be way off base. I was only able to get maybe 60-70% of the reduction drive thrust from my direct drive VW engine.
I can't find the rated RPM for the 32-33 HP Generac. Lower RPMs closer to 2000-2200 RPM would make for a better direct drive engine. RPMs in the 3200-3600 range like a VW make much better reduction drive engines.
Again worth what you paid for it.
Rick Neilsen
Redrive VW Powered MKIIIC
On Wed, Dec 29, 2010 at 10:33 PM, Charlie England <ceengland(at)bellsouth.net (ceengland(at)bellsouth.net)> wrote:
[quote] One of the Generac's attractions for me is that it's designed from the start as an industrial, run all day at rated power, almost any kind of load type of engine. While the power pulses are uneven & may give a reduction drive fits, the engine & in particular the crank should handle almost anything short of a serious resonance issue. VW & other auto engines were never designed to take side loads on the end of the crank, but the Generac crank has a pulley mounted to it in many applications (exception would be direct drive generators).
FWIW,
Charlie
On 12/29/2010 10:06 AM, Rick Neilsen wrote: | Quote: | George
Posted: Thu Dec 30, 2010 11:35 am Post subject: Sonex or GP VW |
Date: Thu, 30 Dec 2010 11:32:51 -0500
Charlie/All
Propeller selection can be a pain too. On the FireFly with the MZ34
mounted, I have run two different IVO propellers. Both have been cut to
about the same radius.
Med pitch 50" prop (at) 14.0 deg - 5,500 rpm -> 23.0 hp (at) 55 mphi
Low pitch 54" prop (at) 8.25 deg - 5,800 rpm -> 24.8 hp (at) 40 mphi
Low pitch 52" prop (at) 8.25 deg - 6,000 rpm -> 26.0 hp (at) 40 mphi
This indicates to me that the low pitch IVO is not a very efficient
propeller for the MZ34/FireFly combination. It is beating the air like
crazy, but it is not passing enough air through the propeller arc to produce
thrust at speed. I have cut the medium pitch IVO down to the limit, and
with it set to minimum pitch, I can not get the engine up to speed. Called
Compact Engines and they do not offer a larger ratio than 2.34 to 1. Called
a propeller fellow and he said he could make a propeller that would do the
job for $700+. Thought about it some more and decided to re-work the
propeller hub and sheave combination to get a 2.60 to one reduction. I
figure this ratio may do the trick. If not, I will go back to the propeller
carvers.
As it flew very well with the medium IVO, I could have left it the way it
was, but there is something about leaving the last four horses in the barn.
Should receive the new sheave next week.
Jack B. Hart FF004
Winchester, IN
Jimmy Young
Joined: 24 Nov 2007 Posts: 182 Location: Missouri City, TX
Posted: Thu Dec 30, 2010 11:59 am Post subject: Re: Sonex or GP VW |
| Quote: | | Valley Engineering souped up the Generac engine,�lightened it a bit, added their reduction drive�and put it on Jimmy Young's Kolb FS. Jimmy�even had to opportunity to fly the plane with the engine installed and choose the best prop by flying a selection of props. With all that it was found to be inadequate for Jimmy. Imagine now that a stock Generac with a dirict drive prop is installed on what George feels is a much lighter FS. Lets also assume that George will get the prop selection perfect and will get conservatively as much as 80% of the thrust of a reduction drive Generec. Jimmy or anyone how well would the plane fly?� |
George/Rick/All;
Here's the way I see it. The Generac (Valley Engineering's version) needs to turn 3600 rpm to develop what was supposedly 38-40 hp. It didn't have enough power to safely fly my FS after 112 hrs of test flying with 4 different props. With the adjustable 72" 3 blade IVO, I pitched it so I was turning over 3800 rpm S&L flight and it was still a dog. It was ok on cool, still, stable early morning air, but heck I fly all the time in all kinds of air and it could not safely cut it at mid-day taking off with a crosswind and 95 degree humid air. It may fly someone else's plane that is much lighter or in a tractor config, but not my 435 lb dry & empty FS, and (at) 750 lbs full fuel/me/& 20 lbs of baggage.
I now have the 60 hp (at) 6200 rpm HKS. Based on that, I should get 50% better performance with it over the Generac. It's more like 90% to 100% better. I'm not so sure the Generac ever developed 40 hp for me.
Valley puts it on their tractor-pull 254 lb backyard flyer and apparently it works well for that plane. Tractor-pull aircraft are more efficient than our pusher-type Kolbs. They know more about the Generac & how to adapt it to aircraft than anyone around.
I've done all the experimenting I care to do with aircraft engines and plan to stick only to a proven design from here on out. More power is more better, time tested proven designs trump what-ifs and how-abouts. Hoping you're going to make it over those trees on take off is not my idea of fun. I scraped the left side gear off my FS 2 years ago because I could not get enough climb taking off in a 90 deg. crosswind blowing over the hangars on a hot day. I aborted the take-off and made a perfect landing. As others have said before on this List, the only problem was I was 15 ft over the runway when I made it. Pilot error was the cause, not the engine, but it was a contributing factor.
Do what you wish, but to go Generac-powered direct drive & a 56" prop in a FS could only be a worse scenario than what I tried, & I would highly discourage anyone from attempting it.
_________________ Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700 |
Dana
Posted: Thu Dec 30, 2010 2:21 pm Post subject: Sonex or GP VW |
Jack, you give rpm at different speeds (level flight I presume). Did you measure the full throttle rate of climb at Vy for each prop? For ma y of us, that would be more meaningful than cruise performance. Rate of climb also directly proportional to power changes.
-Dana
At 02:27 PM 12/30/2010, Jack B. Hart wrote:
| Quote: | Propeller selection can be a pain too. On the FireFly with the MZ34
propeller... |
HAL 9000: Dave. Put down those Windows disks, Dave. DAVE!
Posted: Thu Dec 30, 2010 3:10 pm Post subject: Sonex or GP VW |
Hi Rick,
Most industrial engines have a design rpm of 3600 (works for 60hz generator). A friend has built up a direct drive 992cc Generac & IIRC, the all up weight is a little under 80 lbs. That would mean about the same pwr/wt ratio as a traditional 4 stroke a/c engine.
I wholeheartedly agree that 32-36hp is woefully inadequate for a 700+ lb, very high drag airframe, reduction drive or not. A long, paved strip might make it doable, but not much fun. I'd also agree that prop rpm lower than 3200-3600 would be much better for a high drag, low speed airframe, but I don't see any need to go as low as 2200rpm unless there's room to swing a 6.5-7 foot diameter prop, like the Valley guys are doing on their psru engines. Regular a/c engines swing 72"-74" diameter props at 2700 rpm with excellent efficiency. For efficiency, tip speed is tip speed (determined by diameter & rpm+minor addition for airspeed), & the variable for higher/lower hp is blade area.
A lighter, lower drag airframe is a different story. The Europeans are flying several different designs with decent performance on 20+ hp industrial engines that aren't any lighter than the 36hp Generac.
I think that you're absolutely correct in the context of underpowering particular airframes, but don't see a valid reason for a general dismissal of the industrial engines.
Congrats on your successful VW install. Having had my share of grief with a direct drive VW, I'm glad to see VW's running successfully with reduction drives.
Charlie
On 12/30/2010 10:32 AM, Rick Neilsen wrote: [quote] Charlie/All
Rick Neilsen
| Quote: | One of the Generac's attractions for me is that it's designed from the start as an industrial, run all day at rated power, almost any kind of load type of engine. While the power pulses are uneven & may give a reduction drive fits, the engine & in particular the crank should handle almost anything short of a serious resonance issue. VW & other auto engines were never designed to take side loads on the end of the crank, but the Generac crank has a pulley mounted to it in many applications (exception would be direct drive generators).
FWIW,
Charlie
Posted: Thu Dec 30, 2010 4:16 pm Post subject: Sonex or GP VW |
Date: Thu, 30 Dec 2010 17:14:20 -0500
measure the full throttle rate of climb at Vy for each prop? For many of
Dana,
An amended data table follows:
Climb Rate of
Speed Climb
Med pitch 50" (at) 14.0 deg - 5,500 rpm -> 23.0 hp (at) 55 mphi 45 mphi 300 fpm
Low pitch 54" (at) 8.25 deg - 5,800 rpm -> 24.8 hp (at) 40 mphi 40 mphi ???
Low pitch 52" (at) 8.25 deg - 6,000 rpm -> 26.0 hp (at) 40 mphi 40 mphi ???
The low pitch propeller flights were very short and the engine speed did not
vary until the FireFly was once again over the runway.
Jack B. Hart FF004
Winchester, IN
GeoB
Posted: Sun Jan 02, 2011 9:40 pm Post subject: Sonex or GP VW |
| Quote: | From: "Jimmy Young" <jdy100(at)comcast.net>
Thanks for your comments Jimmy. I am thinking you may be right on, but I
lack the aircraft experience to even guess.
I have not heard that VE hopped up the Generac engine. I would really like
to know what mods they performed for you to get the performance that you did
get (if any mods at all).
I originally bought the Generac before I had my Kolb. It isn't the end of
the world if I don't use the Generac on there. I have a new 503 DCDI in the
garage. My experience is in engine building and modifications. I have
enjoyed pleasing results, some surprisingly good, but am NOT saying I am
anybody's idea of a professional. My interest is/was in seeing how close to
a good aircraft engine I could convert the Generac into. With the torque
peak at +/- 2200 rpm I feel that there remains considerable power and torque
potential remaining untouched here. I have no idea what I will decide to do-
but so far I have been investigating high-torque cams, with my desktop Dyno.
More to go on that. I kinda anticipate doing some manifold and head work.
Not sure the carb yet. I may lower compression some, may mod/replace the
ignition. I think 36 degrees is too much advance for my taste. The gasoline
flywheel has a more reasonable advance. Mine is a propane model.
Jimmy, suppose I had your exact engine, PSRU and a good prop match on my
lighter FS1. Do you have any wild guess what the performance might be then?
You think VE folks could give experienced feedback on that?
GeoB
zharvey(at)bentoncountyca Guest
Posted: Sun Jan 02, 2011 10:44 pm Post subject: Sonex or GP VW |
Hi George.
Love the sound of the VE Generac! I have quite a few trouble hours behind
Rotax 2 strokes (well over 400 hours) but only a few in a Kolb (Firestar
XKP)and I'm wondering if there seems to be issues with the two? Are there
still a lot of folks using the 503 on the Kolb or for some reason is
everyone searching for something else for a given reason? I've been away
from the 2 stroke scene for a goodly number of years, so things may have
changed. Last 2 stroke I had was a 618. A wonderful engine. Any info you
can share with me on the 503 and Kolb Firestar would be much appreciated.
Gene
N71RB Kolb XKP with 503
Posted: Sun Jan 02, 2011 11:00 pm Post subject: Sonex or GP VW |
Should have read "trouble FREE hours"
Gene
From: "Gene & Tammy" <zharvey(at)bentoncountycable.net>
Sent: Monday, January 03, 2011 12:42 AM
To: <kolb-list(at)matronics.com>
Subject: Re: Re: Sonex or GP VW
Hi George.
you can share with me on the 503 and Kolb Firestar would be much
appreciated.
Gene
Jimmy Young
Posted: Mon Jan 03, 2011 10:48 am Post subject: Generac on a FS (was Re: Sonex or GP VW) |
| Quote: | I have not heard that VE hopped up the Generac engine. I would really like
get (if any mods at all). |
GeoB,
The only mods that mine had were an Empi carb, a custom intake manifold, and a custom exhaust. Your best bet would be to call Larry (at) VE & discuss the engine with him regarding what they have done since then. They are very much a customer-service oriented family biz and are great to deal with.
| Quote: | suppose I had your exact engine, PSRU and a good prop match on my
You think VE folks could give experienced feedback on that? |
I would guess a sustainable climb rate of 300-450 fpm. My cruise was the same as with the 503. What did not work for me was very poor & even negative climb rates in hot summer air while trying to overcome the sinks & downdrafts. On nice cool mornings it flew decent, but in mid-day summer air there just wasn't enough power to safely fly the plane IMO.
If I had only a choice between a 503 & a Generac on a FS, I'd take the 503 hands down.
Good luck with your project -
Missouri City, TX
