Okanogan Lew
Posted: Sat Dec 25, 2010 9:30 pm Post subject: CJ6 gear doors |
Guys, has anyone tried extending the lower gear door on a CJ6, so that it totally covers the gear when closed? If so, please share your results. Thanks in advance.
cpayne(at)joimail.com Guest
Posted: Sun Dec 26, 2010 7:43 am Post subject: CJ6 gear doors |
For what purpose would someone cover the main gear wells? If you are thinking drag reduction I would say that there are several other spots on the CJ-6 that would yield a better result for the time/money spent on development.
I say this because I tried it; after a couple of mangled doors that got jammed I gave up before I broke something serious. Later I found that careful fitting of the existing gear door covers yielded a bigger gain than I expected from covering the well. Now I'm not saying that a gear well "slipper" such as the LoPresti product would not help. A Reno-style "gasket" sealing around the wheel in the well, such as on the T-6 may benefit some too.
Tuft testing I did revealed no significant turbulence downstream of the well. I think this is due to high pressure. However there is a problem that gear doors might help with: CO reduction by sealing the gear well against the intrusion of exhaust gases.
Craig Payne
