Water based paint
rfg842(at)cox.net
PostPosted: Fri May 05, 2006 3:27 am    Post subject: Water based paint Reply with quote
Had an interesting conversation with Mike, a retired paint chemist who's =
now
working for Sherwin Williams. Retired after some thirty years with Cessn=
a.=0D
=0D
Said with the advancements in water based paint, only difference with
solvent paints is the gloss and if you put on a coat of clear coat, you w=
on
t be able to tell the difference. Said that Cessna is now using water ba=
sed
paint for the interior of Citations. Advantage is way less fog and over
spray. No big environmental suits for the painters in a confined area. =
=0D
=0D
Reported that most painters prefer the solvent based paints because they =
get
the gloss without the added work load of an extra coat or two of clear co=
at.
=0D
=0D
May be something to consider.=0D
=0D
Bob, Wichita
steveadams
PostPosted: Mon May 08, 2006 3:17 am    Post subject: Re: Water based paint Reply with quote
I think the gloss to the water based polyurethanes is just as good as any other polyurethane. I used the AFS paints and they have a glossy "wet" look like any other polyurethane.
rjscep(at)yahoo.com
PostPosted: Mon May 08, 2006 4:59 am    Post subject: Water based paint Reply with quote
The gentleman I bought the 701 plans from, used
Rustoleum for his "Savannah." He used the low
pressure system. The plane is hangared in an area
that is close to the ocean. Time will tell how the
paint will hold up.
http://forums.matronics.com/viewtopic.php?p=33391#33391
browse
Subscriptions page,
FAQ,
Admin.
