Tim(at)MyRV10.com Guest
Posted: Mon May 08, 2006 8:11 am Post subject: Fuel Valve Extension |
Well, I was one of the early ones, or maybe the first...not sure,
but it's gained a following...
Everyone I know of who's doing this is using the Andair valve,
for which you can order a valve handle extension rod. You also
get a different valve handle and bezel kit for use with the
extension. In addition, depending on how you locate the
valve, you may want the coupler or universal joint, but
in my install I didn't use them. There are also a few
misc. fitting changes you can do to further make the whole
change, but that is on my site.
You may wish to check with Neal George for the extensions
if he has them in stock.
Home - 334-262-8993
Cell - 334-546-2033
neal(at)appaero.com
If not, you can get them from Andair
http://www.andair.co.uk/system/index.html directly. Don't bother
trying to call them as it's hard to get a hold of them. Just
place the order via the web, but it may take a few weeks
to get.
Tim
Conti, Rick wrote:
Tim Olsen,
I believe it was you who extended the fuel value stem to allow lowering
the unit. Can you provide some info on the extension?
Thank You
Rick Conti
Senior Engineering Manager
The Boeing Company
office: 703 - 414 - 6141
blackberry: 571 - 215 - 6134
