Ron Jones
Posted: Tue Jan 04, 2011 2:25 pm Post subject: Fuel hose |
Seasons Greetings to all.
I would be very interested to hear what the latest thinking is on the type /
make of flexible fuel hose is best for handling Un-leaded Mogas now that our
wonderful leaders are insisting on dumping all sorts of horrible additives
into said fuel.
I have an XS with 912S fitted and the hoses have decided they've had enough
and have started weeping!
(I'm weeping, too, at the thought of changing them in this weather!
Regards to all,
Ron Jones (G-RJWX)
rlborger(at)mac.com Guest
Posted: Tue Jan 04, 2011 5:58 pm Post subject: Fuel hose |
Ron,
If you want to stay with flexible rubber you'll probably want to go with the best fuel injection system hose you can find. Over here we'd go to any good auto parts store to get it. Over on your side of the pond it may be different.
Best regards,
Bob Borger
Europa Kit #A221 N914XL, XS Tri-Gear, Intercooled 914, Airmaster C/S Prop
http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232
http://www.biplaneforumgallery.com/index.php?cat=10046
Europa Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Jan 4, 2011, at 16:20, Ron Jones wrote:
I would be very interested to hear what the latest thinking is on the type / make of flexible fuel hose is best for handling Un-leaded Mogas now that our wonderful leaders are insisting on dumping all sorts of horrible additives into said fuel.
I have an XS with 912S fitted and the hoses have decided they've had enough and have started weeping!
Regards to all,
Ron Jones (G-RJWX)
rampil
Posted: Wed Jan 05, 2011 2:15 am Post subject: Fuel hose |
Looks good Ira but they don't appear to mention the conductive coating on the PTFE, it needs to be anti static electricity because minor sparks have been known to pierce the ptfe.
Graham
Sent: Wednesday, 5 January, 2011 3:00:44
Subject: Europa-List: Re: Fuel hose
--> Europa-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
Check this reference:
http://www.gates.com/common/downloads/files/Gates/brochure/TechTipsForm.pdf
R9 hose for impermence, braided stainless forward of the firewall
Ira N224XS
http://forums.matronics; --> http://forums.matronics.com
rampil
Posted: Wed Jan 05, 2011 8:18 am Post subject: Re: Fuel hose |
Hi Graham!
This hose does not have solid inner liner of ptfe. It is therefore
Compatible with the push on connector we are faced with on the older
engines. The Aeroquip 666 which is the ultimate fuel hose on many
specs is in two grades, one with, one without the carbon stripe for
prevent triboelectric phenomena. With that hose you need to be
careful about making sure you have the carbon and that you have
The necessary AN hose fittings because you can not push the Teflon onto
barb connectors
Ira
jan_de_jong(at)casema.nl Guest
Posted: Wed Jan 05, 2011 12:48 pm Post subject: Fuel hose |
Finding Gates (and equivalent Goodyear) 30R9 hard to find I ended up
with equivalent Thermoid injection hose on US trip.
Equally "low permeation" marine hose easily found around here has much
thicker walls these injection hoses.
I only use small sections.
I mainly use alu tubing 5052-O and Aeroquip 666.
All I know on the subject.
Jan de Jong
