dean.psiropoulos(at)veriz Guest
Posted: Wed Jan 05, 2011 10:59 pm Post subject: VM1000 backlighting dimming |
A question for both Bob and VM1000 owners with the original (black and
white) LCD display:
Situation: I bought the VM1000 system in 2002 but it wasn't operating in
the airplane until 2008. Flying at dusk I notice that the LCD screen
backlighting works but is not bright enough for me to read the display. The
VM1000 manual says the backlighting power is generated by a 0-80 volt AC
inverter inside the VM1000 CPU box and that the inverter output is
proportional to the DC voltage on the dimming input of the CPU connector.
The manual notes that full brightness will be achieved when close to full
battery voltage is input at the dimming connection. Unfortunately it does
NOT say exactly what value of "close to full battery voltage" is required to
get full brightness.
Bob:
I installed a B&C dimmer (DIM 5-14, half amp output max) on the dimming
input of the VM1000 CPU connector. I got to talking with someone about the
output of this device and a question came up as to exactly how close to bus
voltage is output when the control is set to full output. I can't recall, is
the output pulse width modulated, and if so, does the device ever achieve a
full bus level output voltage? Or, if the LM317 is a linear device, is the
DIM 5-14 circuit designed to achieve a full bus level output voltage when
the pot is set to full output? If not what percentage of full bus voltage
can I expect? Also, if the DIM 5-14 output is too low can I remove the
circuit board from the equation and just connect the potentiometer (that is
supplied with the DIM 5-14) between the Essential bus and the VM1000 dimming
input to achieve full voltage at the VM1000 dimming input (in other words,
is the potentiometer robust enough for this task or will I burn it up)? Any
other words of wisdom you care to pass on?
VM1000 Owners:
Have any of you come up against this issue? What did you do to solve it?
Were you using a B&C dimmer or some other device? Being the original
designer/owner of Vision Microsystems sold the company and disappeared, does
anyone know exactly what percent of battery voltage is required to get full
output on the display? What failure modes does the display backlighting
system exhibit (i.e. if the backlight works is it just insufficient dimming
input voltage that makes the brightness too low or does the inverter circuit
have failure modes that set the backlighting to some intermediate
brightness)? If so what are those failure modes and can the circuit be
repaired to restore output to full brightness.
Thanks everyone
Dean Psiropoulos
RV-6A N197DM
2 years of flying fun
Posted: Thu Jan 06, 2011 5:41 am Post subject: VM1000 backlighting dimming |
Dean,
I replaced my original VM1000 shortly after Vision Microsystems was sold.
If I recall correctly, Mr. Turk (I think that was his name) was still available through the company that purchased Vision Microsystems. You might try contacting him through the new company.
I don't know if I have enough components remaining to cobble it back together to answer your question as I have been parting out the remnants of mine in hopes of keeping as many of the old systems alive as possible.
Let us know how this pans out as there are a number of us in the curious mode....
Ralph
Posted: Thu Jan 06, 2011 7:45 am Post subject: VM1000 backlighting dimming |
Bob:
The B&C linear dimmers are based on the
LM317 style 3-terminal regulators. They
were intended to service incandescent lighting
where 99% of operating time calls for an
output on the order of 4-5 volts (just
visible in the dark cockpit). These devices
have about a 1.2 volt drop in the max bright
condition. Suggest you wire a spdt switch
to bypass the dimmer and apply full battery
voltage to the VM1000 in the BRIGHT position
and route to the dimmer in the DIM position.
Does this dimmer have any control tasks other
than to control the VM1000?
Posted: Fri Jan 07, 2011 5:15 am Post subject: VM1000 backlighting dimming |
I've got the exact same problem with my older VM-1000 using a B&C
dimmer. I rarely fly at night, so fixing the problem has not been a
priority. It seems that when I first installed the devices, it worked
as advertised with plenty of night lighting. On a recent night
flight, however, the VM 1000 was too dim to use. At some point, I
added another device to the dimmer that supports the VM-1000. I have
supposed that the additional current draw caused the problem, but as
stated, I haven't taken any steps to correct.
The first thing to do is get MEASUREMENTS
as to how much voltage is being applied to
the VM1000 dimming input. Combine this with
an experiment to bypass any existing dimmer
and apply full bus voltage.
Up until recently, the VM-1000 has been supported by an outfit here
in San Antonio (Boerne Stage Airport.) Thanks to my weak memory, I
can't remember the name of the new outfit or the new owner, but I
remember their exact location and I still have their phone number.
They were very helpful a couple of years back when I first flew and
helped me get a different CPU chip for the higher fuel pressure
reading my AFP fuel injection required. I haven't talked to them in a
couple of years, but assume they are still in operation. Their phone
number is (was) 1-830-755-6330. I'll check further to see if they are
still in operation and if they have any suggestions for the dimming problem.
They should suggest the same sort of
investigation and experiments to determine
if there is a VM1000 problem or and externally
induced power supply issue.
When we did the DIM series devices now sold
by B&C, the design goals concentrated on how
a dimmer is used the vast majority of the
time.
When flying in a max dark adjusted condition,
one's visual acuity for seeing things outside
was best if lights inside were just barely
bright enough to read the instruments. Typically
4 or 5 volts on 12 v incandescent lamps. The
short interval that the lamps could use a
full-bright voltage supply was during twilight.
The only time pilots wished such lights were
brighter might be during thunderstorms. The B-52s
I worked on in '61 had "thunderstorm lights." Sealed
beam lamps above the pilot's heads on both
sides. Lightning flashes tended to blind the
crew so it was then useful to have some really
robust flood lighting! I tend to stay away from
thunderstorms . . . they're too loud.
Do the homework to see if the lighting problem
with the VM1000 is internal or externally
caused.
