egp8111
Posted: Sun Jan 09, 2011 11:26 am Post subject: bleed problem |
I'm having trouble bleeding one of the Matco MC-1s on my KFIII rebuild. The fluid won't flow up from the brake to the reservoir at the rudder peddle. I've disconnected the reservoir from the rudder peddle to make sure the piston is fully extended but still no good. The lines are not pinched. Do I need to start pulling the brake itself apart ?
thanks,
EG
Pat Reilly
Posted: Sun Jan 09, 2011 12:01 pm Post subject: bleed problem |
EG, Don't be afraid to call Matco. I called them with a problem and they diagnosed it correctly over the phone. My pedal and linkage was binding up and the piston was not returning to top. It was only about a 1/16th of an inch. But, that was enough to not let caliper pressure relieve and release the brake.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Sun, Jan 9, 2011 at 1:26 PM, egp8111 <egp8111(at)aol.com (egp8111(at)aol.com)> wrote:
| Quote: | --> Kitfox-List message posted by: "egp8111" <egp8111(at)aol.com (egp8111(at)aol.com)>
thanks,
EG
http://forums.matronics.com/viewtopic.php?p=326130#326130
ist Un/Subscription,
www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
Matt Dralle, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
helili(at)chahtatushka.ne Guest
Posted: Sun Jan 09, 2011 1:36 pm Post subject: bleed problem |
I had a similar issue a couple of years ago. I changed the bleeder valve to
standard aircraft bleeder valves and the problem went away.
John Hart
KF IV
Wilburton, OK
dave
egp8111
Posted: Wed Jan 12, 2011 11:39 am Post subject: Re: bleed problem |
I was able to get it sorted out with help from Andy at MATCO. The airplane had been sitting up for a number of years and the piston was stuck in the cailper not letting the fluid through. Andys's tip was to close the bleeder nipple and shoot shop air in the exit hole to the reservoir. It took some messing with but it finally forced the piston out. I cleaned it all up and checked the O ring then reassembled the brake and serviced it. It works and no leaks (yet). good tip and service from MATCO, thanks Andy.
EG
jridgway
Posted: Sun Jan 23, 2011 4:49 pm Post subject: Re: bleed problem |
GOOD LUCK...jack
I FOUND THE MATCO FOLKS VERY HELPFUL.
