dean.psiropoulos(at)veriz Guest
Posted: Mon Jan 17, 2011 8:36 pm Post subject: Oil filters |
Fellow Listers:
My RV-6A has been flying for a couple years now and since I have the
repairman's certificate I've been doing the annuals and maintenance. My
question is on cutting open the oil filter after an oil change. Since I've
never owned an airplane before much less maintained one this exercise has me
wondering:
After the first few oil changes on a new/overhauled engine, do you keep
cutting open the filters and inspecting the element?
Or is inspecting the element not as important as in the first hours after
break in?
Those of you that do cut open the oil filter at every oil change, do you
ever see fine particles in the filter element?
If yes, how often do you see these particles?
What color are the particles?
How large would the particles have to be to be of concern?
Did you notice more of these particles after switching from 50 weight break
in mineral oil to say... 20W-50 ashless dispersant?
How many folks do oil analysis in addition to cutting open the filter?
If the oil analysis says no problem but there are a small amount of fine
particles in the filter do you continue to fly?
If you have fine particles in the filter would you take them to your local
mechanic and have him/her look them over? Or???
I've done lots of work on cars but never cut open the automotive filters so
I don't know if fine particles would be present at every change. I don't
want to be paranoid about this but if a problem can be caught early by
cutting open the filter EVERY TIME then I want to be sure to continue doing
that. Otherwise I'll dispense with that messy exercise. Thanks.
Dean Psiropoulos
Flying fun for 2+ years now
vanremog(at)aol.com Guest
Posted: Mon Jan 17, 2011 9:01 pm Post subject: Oil filters |
Dean-
My opinions only. Do all this at every oil and filter change and you will feel much better about flying yourself and your loved ones over the pointy bits and you will likely grow to be an old man. There are many early signs of engine wear both normal and abbynormal that can be easily discerned by doing same. Both oil analysis and filter examination are needed IMO. Remember, as in a car, when our engine quits we still pull over to the curb, but the curb is a lot further down.
Go to the Blackstone Labs website and get up to speed on this procedure
-GV
In a message dated 01/17/11 20:37:04 Pacific Standard Time, dean.psiropoulos(at)verizon.net writes:
| Quote: | My RV-6A has been flying for a couple years now and since I have the
wondering:
break in?
mrobert569(at)hotmail.com Guest
Posted: Tue Jan 18, 2011 8:05 am Post subject: Oil filters |
Dean,
You definitely want to cut open the filter every time you replace it. If everything is OK then you will find a few black particles that are carbon and easily break up wth your fingers. If you see anything shiny try to pick it up with a magnet. If it doesn't pick up then it aluminum and not to worry about unless it is large particles. If it does pick up thn it is steel. if they are very small particles and there is not large quantities of them then make note ad carry on. If there are are quantities of fine particles or a few large chucks then you need to investigate.
Oil analysis is also a ver cheap good thing to do. It finds wear that can't be caught by the oil filter or the eye (i.e, chromium). What is important is that it sets up a trend that is important to find wear before it becomes a major problem. For example, on Joe's plane, the analysis has shown that he is getting a cylinder wear that is corresponding with one cylinder just starting to lose a little compression. Right now it is not something we need to deal with but it is showing that the cylinder probably will not make TBO times.
I hope you are enjoying the Florida weather and some good flying.
Mike Robertson
> From: dean.psiropoulos(at)verizon.net
| Quote: | To: rv-list(at)matronics.com
Subject: Oil filters
Date: Mon, 17 Jan 2011 23:31:39 -0500
--> RV-List message posted by: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Fellow Listers:
wondering:
break in?
Dean Psiropoulos
[quote] _=====
bicyclop(at)pacbell.net Guest
Posted: Tue Jan 18, 2011 8:27 pm Post subject: Oil filters |
One more thing - check the pickup screen. Big chunks won't show up in the oil filter because the pickup screen got them first. If there's chunks in the pickup screen, you may have a right now kind of problem that looking in the filter and oil analysis might not show up.
Pax,
Ed Holyoke
On 1/18/2011 8:01 AM, Mike Robertson wrote: [quote] Dean,
Mike Robertson
> From: dean.psiropoulos(at)verizon.net (dean.psiropoulos(at)verizon.net)
> To: rv-list(at)matronics.com (rv-list(at)matronics.com)
> --> RV-List message posted by: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net> (dean.psiropoulos(at)verizon.net)
> Fellow Listers:
> wondering:
> break in?
> Dean Psiropoulos
> _=====
