ronlee
Posted: Tue Jan 25, 2011 11:20 am Post subject: unsteady oil pressure |
The last two flights my oil pressure after hot has begun to jump around. At the top end it is the same as it has always been, at 58 PSI hot. It stays there most of the time but occasionally it will bounce from 49-55-58 and then sit on 58 for a while. I know the senders have a tendency to go bad. Any suggestions of a more durable, cheaper one to use? Any suggestions of any other mechanical problems that would cause the problem.
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ Ron Lee
Tucson, Arizona |
Roger Lee
Posted: Tue Jan 25, 2011 11:42 am Post subject: Re: unsteady oil pressure |
Hi Ron,
Haven't heard from you in a while. Hope everything is good.
I would recommend the new parts for the oil pressure regulation. This could be a gauge issue, but the swings are still close enough not to be.
Here are the part numbers for the new Rotax parts. It takes 5 minutes to install. This has stabilized many an oil pressure as that is what it was originally designed for and it may raise your pressure 5 psi or so. I have installed these in at least 20 aircraft. These parts cost about $75
Rotax parts: cap screw 841-983,
Spring 838-122, and oil pressure regulator cone 857-230
Stop on by Ryan some time. We all fly at least twice a week and head out for our breakfast runs all over AZ.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
pchristensen10(at)austin. Guest
Posted: Tue Jan 25, 2011 11:56 am Post subject: unsteady oil pressure |
I had a similar problem and it turned out to be bad ground connection.
Pete
Kitfox III, 912
Leander, TX
On 1/25/2011 1:20 PM, ronlee wrote:
Ron Lee
Tucson, Arizona
http://forums.matronics.com/viewtopic.php?p=328461#328461
Duncan McFadyean
Roger Lee
Posted: Tue Jan 25, 2011 4:42 pm Post subject: Re: unsteady oil pressure |
Grounds certainly do cause gauge swings, but usually they are a little wider apart than Ron's. Ron you can try to tighten all the grounds, but I don't think that will cure this, but who knows. Grounds are considered loose until you put a wrench on them. Remember finger tight, wrench loose. I would still put the other Rotax parts in no matter what you find.
Tucson, Az.
Cell 520-349-7056 |
Dick Maddux
Posted: Wed Jan 26, 2011 6:15 am Post subject: unsteady oil pressure |
in at least 20 aircraft. These parts cost about $75 <
These parts caused my oil pressure to fluctuate all over the place from what was previously a pretty steady indication so I went back to the old original ball /spring which works fine. I guess the old adage of "if it ain't broke ,don't fix it " applies in my case But then I also have a weird 912 Ul of the early 90's vintage . It does lots of things different from anyone else's 912
Dick Maddux
Milton,Fl
Roger Lee
Posted: Wed Jan 26, 2011 7:54 pm Post subject: Re: unsteady oil pressure |
I put these parts in a 2006 Rotax 912ULS today and the plane has a nice steady 55 psi oil pressure, not to mention another 500 hrs onto the TBO.
Tucson, Az.
Cell 520-349-7056 |
wtcef(at)arn.net Guest
Posted: Thu Jan 27, 2011 8:17 am Post subject: unsteady oil pressure |
Roger,
I think this question has been asked before but I couldn't put my finger on
it. We have a 914ul in a Europa XS. Is this a desirable upgrade for
it...and does it extend the TBO on a 914?
Hal Carpenter, Amarillo, TX
Roger Lee
Posted: Thu Jan 27, 2011 2:34 pm Post subject: Re: unsteady oil pressure |
If you are already at 1200 hrs. you don't get any more time. If you are 1000 hrs. you may get 200 hrs more if you qualify. Here is the SB for the 912 and 914. This is Revision 2.
http://legacy.rotax-owner.com/si_tb_info/serviceb/sb-912-041-ul.pdf
Tucson, Az.
Cell 520-349-7056 |
Rich L
Posted: Tue Feb 01, 2011 2:53 am Post subject: Re: unsteady oil pressure |
My oil pressure was 38-42 at 5200 RPM. Actually, it was less at higher rpm's. I just installed the parts Roger recommended and was pleased with the result. A pretty solid 55psi overall. It was 13degF when I tried it today and I was startled when the startup pressure was 83psi. This went down below 65 by the time it got to 120deg. Caused me to recheck the op manual. Thanks Roger.
_________________ Rich Little
N812RL S-7 912ULS
North Idaho
Kiev Prop |
