Posted: Mon Feb 14, 2011 9:12 am Post subject: Power for Checking Systems Out on the Ground |
| Quote: | | Can I hook the power supply up to the battery + and - terminals and use it as a "battery booster" (or would this toast the battery)? Should I just use the battery and charge it overnight with the BatteryMINDer? Other? |
Most power supplies are NOT intended to work
in conjunction with a battery. The primary
difficulty arises when the battery is connected
to a powered down power supply. Output monitoring
and ov protection in many supplies do not like to
be "back fed" from an external power source.
My favorite technique uses a hefty switchmode
power supply similar to this:
http://tinyurl.com/4aoszlf
Combine this supply with a power diode (to
prevent back feeding) and a relay to emulate
the "field control" input on your ship's
alternator. The relay controls 120 vac going
into the power supply.
You can connect this AC mains powered "alternator"
in place of the ship's alternator. With the
alternator emulator ON, adjust the power supply
for a 14.2 volt bus.
The ship's load meter (if installed) can be
used to monitor loads on the power supply. This
will allow you to run the ship's battery in
parallel to let it pick up any transient loads
that might exceed the ratings of the power supply.
| Quote: | | I intend to bring up one circuit at a time and I want to measure each circuit's actual power consumption and I'll need to be careful not to overload the power supply. |
If it's a switchmode supply, it will have built
in overload protection. Further, the supply I
linked above has a thermostatically controlled
fan built in that turns on when the supply is
being taxed to rated output.
Bob . . . [quote][b]
Posted: Mon Feb 14, 2011 12:14 pm Post subject: Power for Checking Systems Out on the Ground |
| Quote: | I have a BatteryMINDer charger/maintainer and a Radio Shack power
supply whose output is rated at 13.8 VDC at 15 Amps.
Should I just disconnect the main battery and use the power supply
in its place? Can I hook the power supply up to the battery + and -
Forgot to touch on this. Your existing supply output
voltage is not high enough to hook directly across a
battery and still have the recommended isolation
(back feed prevention) diode. So you can use the
power supply to emulate a battery. Disconnect
the battery and put the power supply in its place.
Posted: Mon Feb 14, 2011 5:29 pm Post subject: Power for Checking Systems Out on the Ground |
At 05:49 PM 2/14/2011, you wrote:
| Quote: | This may be slightly off topic but is there anything wrong with
charging my a/c battery (modern automatic charger) without
disconnecting from the battery terminals from the a/c? I hook up the
charger occasionally in order to maintain the battery if I am not
flying regularly. Also,if I am testing electrical components such as
radios or lights I have the charger hooked up in order to more
accurately simulate actual alternator operation. The a/c engine is a
Rotax 912UL. Is there something wrong with this reasoning?
No, as long as your external power source is INTENDED
to be connected across a battery (and will not be damaged
if the input power is disconnected while the battery
is still attached) then there's no reason not to leave
it connected during ground ops.
Allen Fulmer
Joined: 10 Jan 2006 Posts: 79 Location: Alexander City, AL
Posted: Fri Feb 18, 2011 7:11 am Post subject: Power for Checking Systems Out on the Ground |
Bob,
I there a drawing showing the circuit you describe below? And values/part no. for the power diode and relay?
Allen Fulmer
Sent: Monday, February 14, 2011 11:07 AM
Subject: Re: Power for Checking Systems Out on the Ground
Bob . . . 01234567890123
_________________ RV7 QB Fuselage
Eggenfellner H6 on orde
N808AF reserved
Alexander City, AL |
Tundra10
Joined: 14 Jun 2010 Posts: 102 Location: Scarborough, Ontario
Posted: Wed Mar 16, 2011 6:00 pm Post subject: Re: Power for Checking Systems Out on the Ground |
I tried to order one of these power supplies, but the vendor in the example was not willing to ship to North America.
I found what appears to be the same product, from anna758595 for $40 which included shipment by mail. I received the product in three weeks, nicely packaged. It is a little smaller than I imagined from the photos, which is nice. I haven't powered it on yet, but I expect it works as advertised. I ended up buying the 13.5V unit, since it can be adjusted upward to simulate battery charging voltage, or down to 12V if I wish. The adjustment is easily accessed without opening the case, tucked in with the terminal strip. Looks like a pretty decent product at a very attractive price.
http://cgi.ebay.ca/13-5V-DC-25-8A-350W-Regulated-Switching-Power-Supply-/150471439243?pt=LH_DefaultDomain_0&hash=item2308cbf38b
Jeff Page
Dream Aircraft Tundra #10
