occom
Posted: Wed Mar 30, 2011 1:39 pm Post subject: need Rotax 582 help. |
I have a slight problem with the exhaust gaskets on my 582 spitting oil.
They don't seem to be loose but oil seems to escape and it tends to be
messy. Has anyone else had this issue and dealt with it successfully? The
manifold is currently held by two bolts per cylinder but I can do three plus
a stud/nut is it will help.
Dave G.
KF IV/ 1050/ 582/ warp
hlang(at)bluewin.ch Guest
Posted: Thu Mar 31, 2011 1:12 am Post subject: need Rotax 582 help. |
Hi Dave
You will need all 4 bolts per cylinder.
Heinz
KF4, R582LC, 500h plus
carlisle
Joined: 20 Jun 2009 Posts: 72 Location: Sioux Falls, SD
Posted: Thu Mar 31, 2011 2:25 am Post subject: Re: need Rotax 582 help. |
My model 2 uses 3 bolts per cylinder/manifold and that seems to work. New or older gaskets?
Chris Carlisle
Model 2, 582, C box
Sioux Falls, SD
akflyerbob
Joined: 06 Jan 2008 Posts: 30 Location: Soldotna, Alaska
Posted: Thu Mar 31, 2011 8:58 am Post subject: Re: need Rotax 582 help. |
If you use a small amount of red/orange high temp RTV
on both sides of the gasket it won't leak the excess oil.
With the exhaust off, rub the engine side across sand paper
on a flat surface to see if its warped.
Also check the oil pump lever for proper alignment, you may
be using to much oil.
_________________ Bob Wolfe..Soldotna, Alaska
KF Mod I and III |
msm_9949(at)yahoo.com Guest
Posted: Thu Mar 31, 2011 10:27 am Post subject: need Rotax 582 help. |
Impossible Heinz. Only 3 of those holes can be accessed on each cylinder when Y pipe is in place. Hi - temp RTV and 2 bolts, diagonally spaced and evenly torqued should solve Dave's problem.
Marco Menezes N99KX
Hersey, MI
Model 2 582-90 C-Box 3:1 w/clutch 66' GSC
--- On Thu, 3/31/11, Heinz Lang <hlang(at)bluewin.ch> wrote:
Subject: Re: need Rotax 582 help.
Date: Thursday, March 31, 2011, 4:23 AM
Hi Dave
Heinz
arget=_blank rel=nofollow>http://www.matronics.com/Navigator?Kitfox-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
| [quote][b]
Guy Buchanan
Posted: Thu Mar 31, 2011 10:42 am Post subject: need Rotax 582 help. |
On 3/31/2011 11:15 AM, Marco Menezes wrote: | Quote: | | Impossible Heinz. Only 3 of those holes can be accessed on each cylinder when Y pipe is in place. Hi - temp RTV and 2 bolts, diagonally spaced and evenly torqued should solve Dave's problem. |
Marco,
I have a stud in the "inaccessible" location and can get a nut and lock washer on it so I end up with all four working.
Guy Buchanan Normal Guy Buchanan 8 20 2010-09-24T17:53:00Z 2011-01-02T22:52:00Z 1 25 149 1 1 173 14.00 <![endif]--> 59 Clean Clean false false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 <![endif]--> <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} <![endif]--> <![endif]--> <![endif]-->
Guy Buchanan
Scoutmaster – Troop 680
760.809.6145
scoutmaster(at)troop680.org (scoutmaster(at)troop680.org)
www.troop680.org
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Posted: Fri Apr 01, 2011 12:25 am Post subject: need Rotax 582 help. |
The word „impossible“ doesn’t exist for Experimental Aircraft Builders J
Heinz
KF4, R582LC
ltaylor02(at)Chartermi.ne Guest
Posted: Fri Apr 01, 2011 1:59 am Post subject: need Rotax 582 help. |
I have three bolts and one stud with a locking nut on the forth for each side. It just takes a little extra time to the stud-nut combination, cut it's secure and leak free.
Lane Taylor
Long EZ N213EZ
Kitfox Model IV N356RL 618 20 hrs and going up...
Posted: Fri Apr 01, 2011 12:41 pm Post subject: need Rotax 582 help. |
As proven by Guy Buchanan's post! I stand corrected.
Marco Menezes N99KX
Hersey, MI
Model 2 582-90 C-Box 3:1 w/ clutch 66" GSC
--- On Fri, 4/1/11, Heinz Lang <hlang(at)bluewin.ch> wrote:
Date: Friday, April 1, 2011, 4:19 AM
Heinz
KF4, R582LC
el=nofollow target=_blank>http://www.matronics.com/Navigator?Kitfox-List
| [quote][b]
