Yak-List: Yak52: Compressor - and replacement U/G bulbs
nigel(at)yakdisplay.com
PostPosted: Mon Apr 04, 2011 10:32 pm    Post subject: Yak-List: Yak52: Compressor - and replacement U/G bulbs Reply with quote
Yes, always cooled to below 150, and no, it never backfires.
Nigel
----- Reply message -----
From: "Didier BLOUZARD" <didier.blouzard(at)gmail.com>
To: "yak-list(at)matronics.com" <yak-list(at)matronics.com>
Subject: Yak-List: Yak52: Compressor - and replacement U/G bulbs
Date: Tue, Apr 5, 2011 5:43 am
--> Yak-List message posted by: Didier BLOUZARD <didier.blouzard(at)gmail.com>
Do you turn off the engine with respect of the procedures.......under 160degre Celsius ....... Without backfire  ???
Didier Blouzard
+33 6 2424 3672
Le 4 avr. 2011 à 23:48, "Nigel Willson" <nigel(at)yakdisplay.com> a écrit :
Thought I'd call on the power of the list.
Two separate enquiries re Yak52.
1. Have had several compressor failures in the last two years - shear pins (rivets) sheared in each case. Replaced each time with correct spec replacements. Compressor itself appears to be fine each time, goes a few hours before the next failure - although never after the same number of hours. Any ideas any one? Anything else to check (apart from replacing the compressor).
2. I've heard that U/C bulbs can be sourced from someone like LUCAS - and all that is required is for the lugs to be filed off. Does anyone know the part number for the official replacement from such a source or similar?
Nigel
ky∑Ëû€"ÕÌú¢Z+”M4”G⁄qÁ(∫∏ûÆw∞rã´âÍ”ÖÊê∏¨¥IöäQhÆÈî±Îax∆≠Æâ‚r¬‚≤—^j€´z√Zæ(∂ä̰∫ˬ«≠ÖÈöü"‚≤€≠äX≠âÎ,π»Z∞∏¨µIˇJÊÏr∏©∂*'∑!ä˜íy™‹Ñ:0ûZw∞⁄»ˬ«ÇÖ´E·¢⁄,Ö™fijwfπ»fπ»f¢∑öÜ∑üÜ€iˇ¸0¬f≠Æâ‚r«(õÛZæ(∂äÿjB‚≤ÿm∂üˇ√ &j⁄Ëû',râø5´‚Å´h≠ܧ.+-˝£Mç $ñNECI©ûÇ∑öµ 'µÈÌj[(jˆ¢ï¶Âz¯ö∂ñy±hÆÈ¨jfi~mߡfl¢ª¶≤f≠Æâ‚r«(ömߡfl¢ª¶≤f≠Æâ‚r«(õˆãäÀB¢{kâª≠äâ÷y¥¢µ‰·jy2¢ÁËØ*.Æßz∫.≤À©¶äÌ1´m∂•ï‚‚≤–ö)⁄Ü∑üÜ€iˇ¸0¬f≠Æâ‚r«(õ˜(û⁄‚nÎb¢xm∂üˇ√ &j⁄Ëû',râørâÌÆ&Ó∂*'˝Ø€˝˙'∑˙k{ˆËw/·∂i
_-============================================================
_-=          - The Yak-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-=   --> http://www.matronics.com/Navigator?Yak-List
_-=
_-=               - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-=   --> http://forums.matronics.com
_-=
_-=             - List Contribution Web Site -
_-=  Thank you for your generous support!
_-=                              -Matt Dralle, List Admin.
_-=   --> http://www.matronics.com/contribution
