rockiedog2
Posted: Mon May 16, 2011 4:42 pm Post subject: Streamlined Strut Covers |
>>>Any suggestions other than removing my slats? They are staying where they are.
Doug MacDonald
CH-701 from scratch
NW Ontario, Canada
Hi Bob
The TAS of my plane increased 5 mph from adding the strut cuffs. The sink decreased and the climb increased also. I did numerous GPS box patterns under varying conditions over several days and finally averaged all the numbers for what should be an accurate real world speed. I never have been able to accurately judge a mod with just one or a few flights.
I suppose one could actually decrease the speed of his plane with the addition of the cuffs. Or induce unwanted pitch or roll inputs. Not to overstate the obvious, but they have to be accurately aligned with the relative wind and one another for maximum benefit. I guessed at it and decided to use the top of the fuse for a reference and must have lucked out. I set the chord of the cuffs parallel with that reference and carefully aligned with one another(made a fixture for all that). Those cuffs would make fine trim tabs, able to affect roll and pitch and create considerable drag if not properly aligned . I didn't get any unwanted trim inputs. Maybe you did all that already; just food for thought...
Good luck
Joe in Mississippi
| - The Matronics Zenith701801-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
NYTerminat(at)aol.com Guest
Posted: Mon May 16, 2011 5:46 pm Post subject: Streamlined Strut Covers |
Doug,
My 701 increased about 4 mph. I agree that the positioning of them is critical. What did you use to align the strut fairings?
Bob Spudis
N701ZX CH701 912S
In a message dated 5/16/2011 8:42:37 P.M. Eastern Daylight Time, jpspencer(at)cableone.net writes:
Quote: | >>>Any suggestions other than removing my slats? They are staying where they are.
Doug MacDonald
CH-701 from scratch
NW Ontario, Canada
Hi Bob
Good luck
Joe in Mississippi
Quote: |
List href="http://www.matronics.com/Navigator?Zenith701801-List">http://www.matronics.com/Navigator?Zenith701801-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
dougsnash
Posted: Mon May 16, 2011 5:50 pm Post subject: Streamlined Strut Covers |
I was careful when aligning my streamlined covers. Their installation has had no negative effect on the control of the plane.
I added one degree of pitch today, up to nine, that added about 1 MPH (as near as I can tell in the thermally air we had today). It reduced my T/O RPM by about 200 RPM to 5200. That is the minimum full power RPM recommended by Rotax. My full power, straight and level is now 5600 so I don't need to worry about overspeeding the engine. I don't know what effect this has had on my climb because of the thermals.
I'm just going to have to accept that this plane is going to be an 80 mph aircraft. That's fine. It certainly is not the lightest example of a 701 with an empty weight of 667 lbs. Maybe I should loose 30 or so lbs and see what that does to my cruise.
Thanks for all of your input guys.
Doug MacDonald
CH-701 from scratch
NW Ontario, Canada
To: Zenith701801-List(at)matronics.com
Sent: Mon, May 16, 2011 7:39:28 PM
Subject: Streamlined Strut Covers
Doug MacDonald
CH-701 from scratch
NW Ontario, Canada
Hi Bob
Good luck
Joe in Mississippi
Posted: Mon May 16, 2011 6:05 pm Post subject: Streamlined Strut Covers |
Is there any way to change the angle of the strut covers? They may not have a negative effect but they are not reducing the drag on the round struts. I know what you mean about loosing weight:) I should also take that advice.
Bob Spudis
In a message dated 5/16/2011 9:50:45 P.M. Eastern Daylight Time, dougsnash(at)yahoo.com writes:
Quote: | I was careful when aligning my streamlined covers. Their installation has had no negative effect on the control of the plane.
Doug MacDonald
CH-701 from scratch
NW Ontario, Canada
Doug MacDonald
CH-701 from scratch
NW Ontario, Canada
Hi Bob
Good luck
Joe in Mississippi
