Goodone
Posted: Mon Apr 11, 2011 11:04 am Post subject: CARBMATE TS-111 ATTACHMENTS TO 912? |
I am considering the purchase of a Carbmate TS-111 for use in synchronizing the carburetors on my ROTAX 912 UL. The basic TS-111 seems to come with cable to connect it to your battery and two lines to connect to the engine. Must I purchase an adapter kit to attach the vacuum lines to the 912 or is the basic Carbmate TS-111 all that I need?
Thanks for any info that you can provide.
dpark748(at)hotmail.co.uk Guest
Posted: Mon Apr 11, 2011 12:45 pm Post subject: CARBMATE TS-111 ATTACHMENTS TO 912? |
It is easier with the two adapters that screw in to the manifold to connect the vac tubes to, then you only have to undo one end of balance tube and block off.
Dave G-LDVO
> Subject: CARBMATE TS-111 ATTACHMENTS TO 912?
[quote] From: goodone41(at)verizon.net
Date: Mon, 11 Apr 2011 12:04:16 -0700
To: rotaxengines-list(at)matronics.com
--> RotaxEngines-List message posted by: "Goodone" <goodone41(at)verizon.net>
http://forums.matronics.com/viewtopic.php?p=336651#336651
rlborger(at)mac.com Guest
Posted: Mon Apr 11, 2011 12:47 pm Post subject: CARBMATE TS-111 ATTACHMENTS TO 912? |
Goodone:
I have one, it works great. It is complete. You shouldn't need anything else for your 912.
Bob Borger
Europa Kit #A221 N914XL, XS Tri-Gear, Intercooled 914, Airmaster C/S Prop
http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232
http://www.biplaneforumgallery.com/index.php?cat=10046
Europa Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Apr 11, 2011, at 14:04, Goodone wrote:
Goodone
Posted: Thu Apr 28, 2011 4:54 pm Post subject: Re: CARBMATE TS-111 ATTACHMENTS TO 912? |
I recently received my Carbmate and we synchronized my friends 912S with success. My friend had a good deal of hose of the same diameter as the cross-over tubing used on the engine. We used plastic adapters to attach his tubing to the small diameter hose supplied with the Carbmate. We just disconnected the 912S cross-over assembly from the intake manifolds on each side of the engine and attached our hose assemblies directly to the manifold fittings on each side of the engine. Worked great!
