Lynn Matteson
Posted: Wed Dec 29, 2010 3:39 am Post subject: airframe grounding |
I don't like that practice....I feel the engine mount bolts should do
JUST that, with nothing else between the bolt and the mount/airframe.
Running the wires directly to the battery or to where the ground
cable connects to the engine is a better procedure, in my estimation.
Lynn Matteson
Jabiru 2200, #2062
Sensenich 62"x 55.5 Wood (winter) until the Prince prop arrives
Rotec TBI-40 injection
Status: flying...1074 hrs (since 3-27-2006)
On Dec 28, 2010, at 6:35 PM, bob noffs wrote:
| Quote: | hi all, i was visiting a friend who bought a ''second hand
''kitfox. i noticed that on at least 2 engine mount to airframe
bolts there was an elect. ring terminal on the bolt . terminals
were to ground all to the battrey. is this recommended/accepted
practice with engine mount bolts?
bob noffs
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Wed Dec 29, 2010 6:57 am Post subject: airframe grounding |
Maybe I ought to give a reason for why I feel as I do...if the
terminal that you are putting under a bolt/nut is copper, it stands
to reason that the copper is soft, and under vibration will squash,
and this leaves the bolt/nut with less tension than when first
installed. Maybe if the bolt/nut were topped off with the terminal
and then another nut that holds the terminal in place would be
acceptable. Has anybody thought of looking in AC43.13 to see the
"acceptable methods"?
Lynn Matteson
Jabiru 2200, #2062
On Dec 29, 2010, at 6:37 AM, Lynn Matteson wrote:
do JUST that, with nothing else between the bolt and the mount/
airframe. Running the wires directly to the battery or to where the
ground cable connects to the engine is a better procedure, in my
estimation.
Lynn Matteson
Jabiru 2200, #2062
> bob noffs
N369LM |
KITFOXZ(at)aol.com Guest
Posted: Wed Dec 29, 2010 8:14 am Post subject: airframe grounding |
As an avionics technician I have to say that you should always strive to make electrical connections clean, dry, tight and separate from any other mechanical purpose. Any engine/airframe bolt or fastener should be for that mechanical purpose only and not shared as an electrical connection.
If four engine bolts hold the engine to the engine mount, that should be their only purpose. A separate grounding bolt should be connected to the engine block for the purpose of connecting a grounding ring terminal. This grounding connection is, among other things, the electrical current path for the negative side of the battery/starter circuit. -A high current connection. You want it to be infallible.
The theory is that an engine mount bolt is there to hold the engine to it's mount. It is a "working" bolt. It is doing an important job of flexing and holding a working member of the aircraft. Although small, this working (flexing) will eventually cause undue wear and tear (corrosion) at the electrical connection if it is a shared connection.
While I am preaching: Additional strain relief of electrical connections is desirable too. You don't want to allow your precious engine block grounding wire ring terminal to be tugged on and flexed while in use. Secure the ring terminal to it's engine block bolt and then protect it from ever seeing any mechanical loads by securing the cable to the engine block via wire tie downs, etc.
John
Columbus, Ohio
Outback, 912S, building
In a message dated 12/29/2010 9:58:31 A.M. Eastern Standard Time, lynnmatt(at)jps.net writes:
| Quote: | --> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Lynn Matteson
Jabiru 2200, #2062
estimation.
Lynn Matteson
Jabiru 2200, #2062
> bob noffs
&g========================; nbsp; (And Get Some AWESOME FREE to find Gifts ilder's ELP b k you for p; -Matt Dralle, List ======================== the ties Day ================================================ - MATRONICS WEB FORUMS ==================================================
Float Flyr
Posted: Wed Dec 29, 2010 5:12 pm Post subject: airframe grounding |
I'm in agreement with Lynn on this one... I think the jumper (Ground braid)
should connect the base of the engine to a solid ground buss on the frame
not to an engine mount where possible electrically induced corrosion can
become an issue.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Wed Dec 29, 2010 5:23 pm Post subject: airframe grounding |
Lynn: the copper in the ring against the 4130 steel of the washer and bolts
is a good place for dissimilar metal corrosion to start... I never
considered the softness of the ring mostly because it is backed by the
rubber elastometric mounting pads which are even softer. I should have
considered that to.
Noel
Kitfox III-A
Float Flyr
Posted: Wed Dec 29, 2010 5:34 pm Post subject: airframe grounding |
Having received my share of slices from unfinished nylon ties under the cowls of aircraft I am left with two words. Cora Seal... learn how to use it!
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of KITFOXZ(at)aol.com
Sent: December 29, 2010 12:40 PM
Subject: Re: airframe grounding
John
Columbus, Ohio
Lynn Matteson
Jabiru 2200, #2062
estimation.
Lynn Matteson
Jabiru 2200, #2062
> bob noffs
&g========================; nbsp; (And Get Some AWESOME FREE to find Gifts ilder's ELP b k you for p; -Matt Dralle, List ======================== the ties Day ======================= - MATRONICS WEB FORUMS
| 0123456789012345
Kitfox III-A
WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Mon May 02, 2011 7:27 am Post subject: Re: airframe grounding |
I am gonna drag up this old post since I am swapping out engines and have decided to desire the whole plane in the process. My plane also has the motor mount bolts operating as a ground and I would like to remedy this. So what is the best method? I am thinking it would be good to get a bus that could be connected to the battery and the engine block with wires and the bus or grounding block could then be mounted behind the instrument panel. Should the airframe also be connected to this? Where is a good place for airframe attachment if so? Thanks for any input.
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
Vic Baker
Joined: 11 Jan 2006 Posts: 71 Location: Carson City, Nevada
Posted: Mon May 02, 2011 8:25 am Post subject: airframe grounding |
James,
Good question. Unwanted ground loops will cause radio noise. Here's what I
did:
On the engine mount, the one that bolts to the firewall and airframe, there
is a tab intended for ground connection. I connected the engine case (#6
AWG), the battery neg terminal (#6 AWG) and the "ground" bus bar that is
located behind the panel (2 each #14 AWG) to this point.
All ground returns from the aircraft electrical equipment connect to the
"ground" bus bar.
The result is that there is no current flow in the airframe itself. My
radio is noise free.
One exception, the transponder and transceiver antennas do connect to the
airframe. (easier than making an isolated ground plane for each)
Hope this makes sense.
Vic
Vic Baker
S7 912S Warp
Carson City, Nv
_________________ Vic Baker
Series 7
Carson City, Nevada |
Guy Buchanan
Posted: Mon May 02, 2011 12:57 pm Post subject: airframe grounding |
On 5/2/2011 8:27 AM, WurlyBird wrote:
| Quote: | Should the airframe also be connected to this? Where is a good place for airframe attachment if so? Thanks for any input.
I have this 3/8" brass bolt that goes through the firewall, location
irrelevant. On the engine side I have a braid strap that connects it to
the engine. On the passenger side it goes through a brass
"forest-of-tabs" ground bus I got from B&C specialty products. The
battery negative connects to the passenger side of the bolt. All powered
items are grounded at this bus. Nothing goes through the airframe. Audio
grounds are to a separate bus near the audio stack, which is then
grounded to the firewall bus. This helps isolate the communications
grounds from power.
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 592-C / Warp 3cs / 500 hrs. and grounded
Deceased K-IV 1200
A glider pilot too. |
lcfitt(at)sbcglobal.net Guest
Posted: Mon May 02, 2011 5:12 pm Post subject: airframe grounding |
This is an interesting question. I am working on a Model IV and a Series V
with 7 FWF. I understand the theory regarding no current flow through the
airframe, but the V has capacitance fuel level senders which recommend two
grounds. One to the negative buss and one to a "local ground". I did the
IV a bit different from Vic's method which is the factory design for the 7
by running the negative battery cable straight to the engine - no extra
connections and no loss possibility. Then a length of braid runs to an adel
clamp connecting to the ignition module grounds. The buss ground runs from
the battery to the negative buss bar. As of yet I have not decided how to
ground the fuselage.
Lowell
Sent: Monday, May 02, 2011 9:22 AM
Subject: Re: Re: airframe grounding
James,
I did:
there is a tab intended for ground connection. I connected the engine
case (#6 AWG), the battery neg terminal (#6 AWG) and the "ground" bus bar
that is located behind the panel (2 each #14 AWG) to this point.
"ground" bus bar.
Vic
Vic Baker
S7 912S Warp
Carson City, Nv
WurlyBird
Posted: Mon May 02, 2011 6:00 pm Post subject: Re: airframe grounding |
Well I talked to Jerry at GreenSky Adventures who is the one setting up my HKS and he is going to add a dedicated tab to the engine mount to be used as a common ground. So this point will connect to the battery (-), the engine ground and will connect to a (-) bus behind the panel. I am happy with this idea.
Concerning HKS engines I highly recomend dealing with Jerry. He is great to work with. And very patient which is good because I have been bugging him about this engine idea for almost a year.
