fuel line routing with Airflow Performance FI
rnewman(at)tcwtech.com
PostPosted: Tue May 10, 2011 5:49 pm    Post subject: fuel line routing with Airflow Performance FI Reply with quote
Fellow builders I’m looking for some clear photos of the fuel line routing used to get from the mechanical fuel pump to the fuel controller throttle body when using the Airflow Performance fuel injection system on the IO-540. The black and white photos in their install manual are nearly useless. I’ve done some basic searching of the usual suspect’s web sites but haven’t found what I’m looking for (both routing and clamp placement ideas). I’m also interested in the routing of the throttle and mixture cable. At present it appears that the best layout is on the left side of the engine (under cylinders 2-4-6) for both push cables, would appreciate any input folks have regarding this set-up.
Thanks for the input!
Bob Newman
40176
under the cowling [img]cid:E4C510CA873843C488444D1C56040E61(at)Boblaptop[/img]
 Filesize:  1.02 KB
 Viewed:  1680 Time(s)
Deems Davis
PostPosted: Tue May 10, 2011 7:07 pm    Post subject: fuel line routing with Airflow Performance FI Reply with quote
