sean(at)stephensville.com Guest
Posted: Tue May 24, 2011 2:24 pm Post subject: Round SubPanel Doubler |
For those that are using doublers in the subpanel for round holes cut
for wire pass-through, are you making your own using a fly cutter or are
there pre-made doublers available from some source?
-Sean #40303
stein(at)steinair.com Guest
Posted: Tue May 24, 2011 2:42 pm Post subject: Round SubPanel Doubler |
For something like a small round hole that you feed wires through, no
doubler would really be needed...think of it as a "lightning hole"!
Stein
Posted: Tue May 24, 2011 2:59 pm Post subject: Round SubPanel Doubler |
Ya, I was thinking something a bit larger. Something a pre-built
harness (made by some reputable avionics shop ) with a DB25 already
on could pass through without pulling all the wires out of the connector.
I know Vans recommends anything over 2 inch diameter be reinforced.
Stein
Posted: Tue May 24, 2011 3:22 pm Post subject: Round SubPanel Doubler |
On 5/24/2011 6:40 PM, Stein Bruch wrote:
Are lightning holes followed by thunder???
Sorry, couldn't resist!!!
Linn
[quote] Cheers,
Stein
Posted: Tue May 24, 2011 4:02 pm Post subject: Round SubPanel Doubler |
On 5/24/2011 6:57 PM, Sean Stephens wrote:
You can take the DB-25 connector shell apart and lay the cable alongside
and fit it through about a 3/4" - 1" hole. After getting it through,
just replace the shell.
Linn
> Cheers,
> Stein
