dlm34077(at)q.com Guest
Posted: Tue May 24, 2011 9:21 am Post subject: fuel pressure sensor |
I have a GRT sensor which is occasionally providing a reading of 38 psi which puts me into the out of limits condition for the Chelton displays. Normal reading is about 29 psi. part total time is about 450 hours. anyone else had sensor problems? I carry a replacement in the tool/parts box so I can change it but trying to confirm that it needs to be replaced. Engine continues to perform properly.
rv10rob(at)gmail.com Guest
Posted: Tue May 24, 2011 9:41 am Post subject: fuel pressure sensor |
Don't know if it's the same sensor, but my one from Dynon lasted about 25 hours, before it started "oscillating" with the boost pump off. Replaced it, and the problem was fixed... for about 5 hours. Seeing the same issue again.
On Tue, May 24, 2011 at 10:17 AM, DLM <dlm34077(at)q.com (dlm34077(at)q.com)> wrote:
| Quote: | I have a GRT sensor which is occasionally providing a reading of 38 psi which puts me into the out of limits condition for the Chelton displays. Normal reading is about 29 psi. part total time is about 450 hours. anyone else had sensor problems? I carry a replacement in the tool/parts box so I can change it but trying to confirm that it needs to be replaced. Engine continues to perform properly.
ttp://forums.matronics.com
Rob Kochman
RV-10 Flying, Phase 1
Woodinville, WA
http://kochman.net/N819K
rene(at)felker.com Guest
Posted: Tue May 24, 2011 9:49 am Post subject: fuel pressure sensor |
My normal pressure is in the low 20’s, but I saw some spikes after the first year…….ended up being a faulty ground connection. The crimp just was not good enough. Worked fine ever since. 170 hours.
Rene' Felker
N423CF
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM
Sent: Tuesday, May 24, 2011 11:18 AM
Subject: fuel pressure sensor
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234567
Posted: Tue May 24, 2011 11:14 am Post subject: fuel pressure sensor |
have not decided what to do at this point but may look for an automotive solution or a certified solution.
Posted: Tue May 24, 2011 12:42 pm Post subject: fuel pressure sensor |
I found that the VDO sensors used for oil and fuel pressure are 360004 and 360003 and are automotive senders. I checked with EI and found that we are "locked in" to VDO sensors check for pressure. I did replaced egt probes with EI and have had no further problems with egt probes burning /disintegrating.
http://www.jegs.com/p/VDO/VDO-Pressure-Senders/887192/10002/-1
dmaib(at)mac.com Guest
Posted: Tue May 24, 2011 3:18 pm Post subject: fuel pressure sensor |
I just replaced my second GRT fuel sensor a few weeks ago. Both sensors started giving erroneous high readings intermittently in my Cheltons and on Vertical Power. Sandy at GRT says this is pretty common with this sensor. It is a five minute job to swap sensors, but it is a PITA when it starts giving you false alarms. I changed the first one at approximately 175 hours, and this recent one at about 350. I can't remember the cost, but I think it was in the $35 to $45 range.
David Maib
40559
Flying
Posted: Tue May 24, 2011 8:03 pm Post subject: fuel pressure sensor |
try link I posted. About $23.
