Tim Olson
Posted: Sun Jun 05, 2011 10:46 am Post subject: GRT EIS fuel pressure sender - "better" |
Before I was even flying and while I bought my stuff, I had asked GRT if what I was buying was the best I can do on stuff. They said that many Lancair folks buy this fuel pressure sender instead of the standard one they supply. Knowing that most Lancair builders don't care about $10 or $20 upcharges, as I don't either, if it gives better quality, I purchased this sender. It's been flawless for 725+ hours. The oil pressure sender is their standard one and has also been flawless.
You might want to just get the better sender if you have problems. See attached:
P/n: 2000132
Model: MSP-300-100-P-4-A-1
<pre><b><font size=3D2 color="#000000" face=3D"courier new,courier">
484.38 KB |
2015 Time(s) |
scottmschmidt(at)yahoo.co Guest
Posted: Tue Jun 07, 2011 8:28 am Post subject: GRT EIS fuel pressure sender - "better" |
I bought the same sender from the beginning.
I would also recommend the higher end EGT probes.
-Scott
On Jun 5, 2011, at 12:13 PM, Tim Olson <Tim(at)myrv10.com> wrote:
| Quote: | Before I was even flying and while I bought my stuff, I had asked GRT if what I was buying was the best I can do on stuff. They said that many Lancair folks buy this fuel pressure sender instead of the standard one they supply. Knowing that most Lancair builders don't care about $10 or $20 upcharges, as I don't either, if it gives better quality, I purchased this sender. It's been flawless for 725+ hours. The oil pressure sender is their standard one and has also been flawless.
P/n: 2000132
<photo.JPG>
</b></font></pre>
Tim Olson
Posted: Tue Jun 07, 2011 8:40 am Post subject: GRT EIS fuel pressure sender - "better" |
Ditto...as Scott says, ask them (GRT) for the Hastelloy EGT
probes if you ever change EGT probes.
On 6/7/2011 11:25 AM, Scott Schmidt wrote:
-Scott
> P/n: 2000132
> <photo.JPG>
> </b></font></pre>
