natosmith
Posted: Fri Jun 24, 2011 8:47 am Post subject: Tail replace/repair |
I'm helping someone repair a Firestar and a Twinstar. He has plans from 1987 that show a different tail assembly than what I've seen in some of the Kolb videos. Would someone out there be willing to take a few pictures of the vertical tail installation with the ring? His is an older style that doesn't have the ring, but it needs to be replaced. I'm not sure how to attach the new style assembly, or even what parts I need to order.
Nate
Thom Riddle
Posted: Fri Jun 24, 2011 9:43 am Post subject: Re: Tail replace/repair |
Nate,
Another approach would be for you to take some photos of what you have and send them to Travis at Kolb and then call him and ask him what you need, which will come from him in any case, unless you have a junker you can scavenge the parts from.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
WhiskeyVictor36(at)aol.co Guest
Posted: Mon Jun 27, 2011 7:35 pm Post subject: Tail replace/repair |
Nate,
I have the early model and my buddy has the later model Kolb tail weldment assembly. I will try to relate what I see as the difference.
The early model Kolbs used a tail weldment that consisted of a vertical tube and two horizontal tubes. The horizontal tubes are positioned inside the boom tube against the top and bottom and riveted to the boom tube lengthwise.
The later version uses the ring, which is inserted into the boom tube and riveted around the circumference.
This change was made to eliminate the step of removing the pin that connects the elevator horn to the elevator controller mechanism, in order to fold the tail, on the early style. The newer ring type has a pivoting joint that allows folding, without having to remove a pin.
The elevators for the ring type use a different type of horn and I'm not sure if the early elevators could be retrofitted.
There is also a difference in the design of the horizontal stabilator, at the inboard aft end. I think this was to give clearance for the pivoting joint. The early model has the corner tubes butted together at a right angle, while the ring type has a gap there. I don't think they would be interchangeable. If you were to install the new ring type on an early model, you may have to build new, or modify the existing, horizontal stabilators.
Hope this helps a little bit,
Bill Varnes
Original Kolb FireStar
Audubon NJ
In a message dated 6/24/2011 12:49:52 P.M. Eastern Daylight Time, natosmith79(at)gmail.com writes:
| Quote: | the vertical tail installation with the ring? His is an older style that doesn't have the ring
