enginerdy(at)gmail.com Guest
Posted: Fri Jul 01, 2011 4:08 pm Post subject: Antenna static discharge protection |
I'm curious if anyone has experience with protecting RF circuits from
static buildup on exposed antennas during flight.
What is required? Assuming the circuit can only withstand small
voltages (10-20V), is a 100V ceramic blocking capacitor with a 1Meg
drain resistor sufficient? Do you need some sort of diode or gas
discharge device?
Has anyone done or seen research on how quickly voltages can rise (or
fall) on an antenna element in flight?
I'm looking at ham radio-type stuff here, so don't assume a nice,
robust nav/com radio
Daniel
Posted: Fri Jul 01, 2011 5:24 pm Post subject: Antenna static discharge protection |
At 07:04 PM 7/1/2011, you wrote:
What kinds of circuits? Radios designed for the
aircraft environment are already so protected.
| Quote: | What is required? Assuming the circuit can only withstand small
discharge device?
Not sure about rates of rise but intensities can
be very high . . . 100Kv type high
| Quote: | I'm looking at ham radio-type stuff here, so don't assume a nice,
Voltages are high, but energies and currents are
very low. A simple inductor across the antenna lead
to ground having negligible conductivity at frequencies
of interest are quite sufficient.
A 1000 ohm resistor across a 50 ohm transmission
line would have negligible effect on swr and/or
lost energy . . . and a profound effect on buildup
of precipitation static.
Posted: Fri Jul 01, 2011 7:46 pm Post subject: Antenna static discharge protection |
| Quote: | Voltages are high, but energies and currents are
Ah! I hadn't considered a shunt inductor!
Thanks for the info! If anyone else knows where to find data on in flight ESD I'd still love to see it.
Posted: Sat Jul 02, 2011 6:32 am Post subject: Antenna static discharge protection |
At 10:40 PM 7/1/2011, you wrote:
| Quote: | Ah! I hadn't considered a shunt inductor!
We had a big shake-up at Beech about 25 years
ago to deal with some static discharge wick issues
on the fleet. There are pretty simple bench tests
to test the relative effectiveness of a static
wick. I'm aware of no flight test data . . . you
might poke around in the patents (freepatentsonline.com)
and NASA documents.
