ChangDriver
Posted: Sun Jul 17, 2011 3:58 am Post subject: EGT Readings Change when Transmitting |
Bob:
I have noticed an odd thing happening on my digital EGT display. When I key the microphone to transmit on the Garmin SL-30, the graphical EGT display bars are driven down to zero. I short key of the mic and they go down a little....hold it keyed and they go to zero.
Any suggestions on what to look for/do?
Craig
Posted: Sun Jul 17, 2011 6:55 am Post subject: EGT Readings Change when Transmitting |
At 06:58 AM 7/17/2011, you wrote:
Bob:
In all likelihood this is a manifestation
of poor design in EGT gauge's electro-
magnetic compatibility. Since you know
the condition exists and does not represent
a hazard to flight or even an operational
inconvenience, I'd ignore it.
keithward1(at)bellsouth.n Guest
Posted: Sun Jul 17, 2011 12:08 pm Post subject: EGT Readings Change when Transmitting |
Craig,
I had an issue with my EFIS that sounds similar to yours. When I keyed the mike, most of my readouts (vsi, heading, etc.) moved. I changed the BNC connectors and the problem was solved. I think I did a poor job installing the original connectors.
Not sure if this would fix your issue, but it may be worth a try.
Keith
On Jul 17, 2011, at 7:58 AM, "ChangDriver" <capav8r(at)gmail.com> wrote:
Bob:
Craig
http://forums.matronics.com/viewtopic.php?p=346751#346751
