Ray.R.Doerr(at)sprint.com Guest
Posted: Fri May 19, 2006 8:14 am Post subject: What fuel pressure should I see for electric or engine fuel |
What fuel pressure should I see for the electric and/or the
engine fuel pump. The Lycoming operators manual talks abour 40 being
the max, but when I run the electric pump I get 6 and when the engine is
running at idle, it is also around 6 with the electric one off. Does
this sound normal for an Injected IO-540?
Thank You
Ray Doerr
40250 (First engine run went great)
