ronrvbuilder(at)bigpond.c Guest
Posted: Sun Jul 31, 2011 7:24 pm Post subject: What is the difference between Lycoming YIO-540 and XI)-540 |
As a minimum, the YIO-540 contains roller tappets. Not sure that the XIO necessarily does.
cheers
Ron
VH-XRM in Oz
---- "bill.peyton" <peyton.b(at)sbcglobal.net> wrote:
You purchased the experimental non-certified version of the engine. The certified costs around $3K more! In reality it is the identical engine, just a different part number....... Call Lycoming, I did.
Bill Peyton
Kelly McMullen
Posted: Mon Aug 01, 2011 12:20 pm Post subject: What is the difference between Lycoming YIO-540 and XI)-540 |
Having discussed the issue with the folks at Precision, the only
difference between their experimental units and certified is the color
of the servo body and the data plate. They are otherwise identical.
On Mon, Aug 1, 2011 at 12:19 PM, rv10flyer <wayne.gillispie(at)yahoo.com> wrote:
I have YIO-540 too. Fuel servo, flow divider, fuel nozzles and data plate are different but still must meet same test cell specs.
Wayne Gillispie, A&P 5/93, PPC 10/08
Bldr# 40983SB IO-540 Install.
http://forums.matronics.com/viewtopic.php?p=348283#348283
A&P/IA, EAA Tech Counselor
KCHD |
