msm_9949(at)yahoo.com Guest
Posted: Mon Aug 08, 2011 12:16 pm Post subject: Stick grip |
I'm looking to replace my current PTT stick grip (basic Ray Allen) with one that has the PTT in a "trigger" position, like the old P-51 grips. Nobody seems to make one of those with just one momentary contact switch. Plenty of them are around festooned with multiple switches but all I need is one simple switch in the trigger location. On-line search has been fruitless so far. Any ideas?
Marco Menezes (N99KX)
Model 2 582-90 C-Box w/clutch
Hersey, MI
Lynn Matteson
Posted: Tue Aug 09, 2011 8:01 am Post subject: Stick grip |
Which color?.....that is if I can find them. I had two left over
from my build, a white and a black, without switches, but they are
buried by something, somewhere. They're yours if I can locate them,
Marco.
Lynn Matteson
Jabiru 2200, #2062
Prince prop 64 x 30, P-tip
Rotec TBI-40 injection (sleeved to 36mm)
Status: flying with "Ramcharger" intake manifold...1155 hrs (since
3-27-2006)
On Aug 8, 2011, at 4:13 PM, Marco Menezes wrote:
| Quote: | I'm looking to replace my current PTT stick grip (basic Ray Allen)
Hersey, MI
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
n223rv(at)wolflakeairport Guest
Posted: Tue Aug 09, 2011 9:00 am Post subject: Stick grip |
You can get Infinity grips with any configuration you like. They aren't cheap, but they do make them custom and have a trigger position...
On Aug 8, 2011, at 4:13 PM, Marco Menezes <msm_9949(at)yahoo.com (msm_9949(at)yahoo.com)> wrote:
[quote]I'm looking to replace my current PTT stick grip (basic Ray Allen) with one that has the PTT in a "trigger" position, like the old P-51 grips. Nobody seems to make one of those with just one momentary contact switch. Plenty of them are around festooned with multiple switches but all I need is one simple switch in the trigger location. On-line search has been fruitless so far. Any ideas?
Hersey, MI
Posted: Tue Aug 09, 2011 1:55 pm Post subject: Stick grip |
Wow! Black if you can find it Lynn, but I'll take either one. I can always paint the white one.
Thanks Lynn!
Marco Menezes N99KX
1881 Cody Trail
Hersey, MI 49639
--- On Tue, 8/9/11, Lynn Matteson <lynnmatt(at)jps.net> wrote:
Subject: Re: Stick grip
Date: Tuesday, August 9, 2011, 11:58 AM
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
Which color?.....that is if I can find them. I had two left over from my build, a white and a black, without switches, but they are buried by something, somewhere. They're yours if I can locate them, Marco.
Lynn Matteson
Jabiru 2200, #2062
Status: flying with "Ramcharger" intake manifold...1155 hrs (since 3-27-2006)
| Quote: | I'm looking to replace my current PTT stick grip (basic Ray Allen) with one that has the PTT in a "trigger" position, like the old P-51 grips. Nobody seems to make one of those with just one momentary contact switch. Plenty of them are around festooned with multiple switches but all I need is one simple switch in the trigger location. On-line search has been fruitless so far. Any ideas?
Model 2 582-90 C-Box om/Navigator?Kitfox-List" --> http:========================
| [quote][b]
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Tue Aug 09, 2011 5:13 pm Post subject: Re: Stick grip |
Ff all else fails on the trigger switch, you should be able to get a momentary push button switch at the local auto parts.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Lynn Matteson
Posted: Wed Aug 10, 2011 2:56 am Post subject: Stick grip |
I looked at home here and the hangar, but they didn't show up
yet....I recall putting them in a small box....I don't recall tossing
them away, that's for sure. I'll keep looking.
Lynn Matteson
Jabiru 2200, #2062
Status: flying with "Ramcharger" intake manifold...1156 hrs (since
3-27-2006)
On Aug 9, 2011, at 3:51 PM, Marco Menezes wrote:
| Quote: | Wow! Black if you can find it Lynn, but I'll take either one. I can
Thanks Lynn!
Marco Menezes N99KX
1881 Cody Trail
Hersey, MI 49639
Marco.
Lynn Matteson
Jabiru 2200, #2062
3-27-2006)
N369LM |
WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Wed Aug 10, 2011 4:44 am Post subject: Re: Stick grip |
On the trigger topic, have any of you ever seen a two detent PTT trigger? Heck a two detent button would be nice too. Currently I have two buttons on the stick, PTT and push to intercom and I would love to combine those.
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
Lynn Matteson
Posted: Thu Aug 11, 2011 4:35 am Post subject: Stick grip |
I've turned the shop and the hangar upside-down and can't find them,
Marco...sorry to get your hopes up. I either gave them away or tossed
them, and that doesn't seem likely.
Lynn Matteson
Jabiru 2200, #2062
3-27-2006)
Thanks Lynn!
Marco Menezes N99KX
1881 Cody Trail
Hersey, MI 49639
Marco.
Lynn Matteson
Jabiru 2200, #2062
3-27-2006)
N369LM |
