Dave(at)AirCraftersLLC.co Guest
Posted: Fri May 19, 2006 9:22 am Post subject: What fuel pressure should I see for electric or engine fuel |
Ray,
Metered fuel pressure downstream of the servo is around 5 psi with little if
any change when the electric pump comes on.
If you measure fuel pressure just downstream of the mechanical pump, before
the servo, you should be able to see the electric pump boost the pressure to
30-40 psi. That's how you know it's working. The mechanical pump alone
should keep it around 20-30 psi. 6 psi is about right for a carbureted
engine. Carbureted engines use a lower pressure mechanical fuel pump
compared to injected engines.
Dave Saylor
AirCrafters LLC
831-722-9141
