Kellym
Posted: Sat Sep 10, 2011 5:55 am Post subject: Transponder troubles |
Had strange occurrence with Salt Lake Approach yesterday. Initially,
when they said they couldn't see my transponder, I had a reply light.
Then they said they could see a 1200 code from it, not the 0363
assigned that I had dialed in. A bit later they saw the correct code,
and it continued to be okay until out of their airspace. Now I
departed the Phoenix area the day before, communicating with 2 radar
equipped towers that had no complaints on my transponder and were
giving me radar traffic callouts, so I know it was working. Not sure
how a transponder could possibly put out a 1200 code when set to
something else, and then revert to sending the selected code. I could
see one or two digits being wrong, but the whole code? I could only
think they had a weak signal, but checked after I landed and antenna
was clean. I guess I can check the coax connection, and reseat the
unit in its tray, but would rather not have to spend for an
unnecessary bench check. It is an old model with cavity tube, but has
been rock solid since it was aligned 8 yrs ago, passing every biennial
check. Any other thoughts?
KCHD |
Posted: Sat Sep 10, 2011 6:38 am Post subject: Transponder troubles |
Don't worry about it . . . yet. Aviation electronics, transponders
in particular are prime examples of what CAN happen when one agency
with no particular expertise has the power to mandate behaviors
to others without regard or responsibility for the unintended
consequences.
Modern transponders are descendants of the WWII IFF (identification,
friend or foe) systems that helped avoid shooting down our own
airplanes. The Mode A (identification only) systems of the 1960's
were relatively simple pulse generators tide to an almost stable
high power oscillator that would, most of the time, let the guy
on the ground sort your primary radar return from perhaps hundreds
of other returns.
Then they added altitude reporting by making this little bitty
change to the pattern of pulses . . . that were supposed to let
the system on the ground tell the difference between two closely
spaced string of pulses . . . first being I.D. the second being
altitude. Of course, there were volumes of specifications written
to which willing players complied so that they could play in the
avionics sand-box.
When some transponders failed to deliver a flavor of pulses
distasteful to the ground systems, it was discovered that the
agency in question 'made a mistake' in writing the specifications.
The cost of a work-around nearly sank Terra. This is but one
of many examples for how our avionics and the efficiency to which
they perform has be regulated into inept antiquity . . .
While the rest of the universe is communicating in digital
spread spectrum, we still talk on radios that suck for air
(VHF AM). This is but a hand-full of examples of system
evolution that has been subject to administrative retardation.
Yeah, it's getting "better" . . . but only by stacking band-aid
on top of band-aid to a system that should have been trashed
and replaced decades ago. You've got more capability, flexibility
and utility in the computer upon which you're reading these words
than the FAA has in their radar systems they depend on to tell
other folks what to do . . . ostensibly to keep them from running
into each other. It's sorta like sending a one armed man blind
in one eye into a sword fight with a atomic powered table knife.
If he's VERY talented, he'll be okay most of the time.
So when somebody on the ground says there's something wrong
with your radios, do your own due diligence but don't be surprised
if the difficulty cannot be identified or repeated. His
perceptions are altered by systematic retardation and may
not always be accurate.
at6c(at)bellsouth.net Guest
Posted: Sat Sep 10, 2011 8:19 am Post subject: Transponder troubles |
It's ATC problem. I have had the same issue with ATC on a number of
occasions, if one radar site has a problem and nobody else does I wouldn't
be in a hurry to get to the repair shop.
George
ainut(at)knology.net Guest
Posted: Sat Sep 10, 2011 8:46 am Post subject: Transponder troubles |
interference from something else?
If you're an American, just say NO to the Obamanation, to socialism, and get rid of Soros.
..democracy and a republic can function only in a firm partnership with morality and religion. -- John Adams. Indeed. Same should be said for ANY type of gubmnt
Speedy11(at)aol.com Guest
Posted: Sun Sep 11, 2011 8:43 am Post subject: Transponder troubles |
Bob,
Perfectly worded. Sounds like Congress.
Stan Sutterfield
In a message dated 9/11/2011 3:01:15 A.M. Eastern Daylight Time, aeroelectric-list(at)matronics.com writes:
consequences.
