Posted: Fri May 19, 2006 7:17 pm Post subject: MB antenna length |
Where is the source for a 40" MB coax antenna? All I find in the Connection
is a 75" length for a quarter wave balun.
Rob Wright
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Sat May 20, 2006 7:09 am Post subject: MB antenna length |
On May 19, 2006, at 8:10 PM, Robert G. Wright wrote:
<armywrights(at)adelphia.net>
Connection
Antennas don't necessarily need to be resonant and/or efficient. If
you have a lot of signal you might not need a lot of antenna.
Consider that a marker beacon transmitter may run 50W of power or so
into a directional antenna beaming it straight up at your airplane.
Now consider that you need to receive it from only a couple thousand
feet away at most. It doesn't take a lot of antenna at the receiver
to pick up that signal.
Frankly, just about any piece of wire will suffice as a marker beacon
antenna.
So, take a piece of coax, strip the shield off of about 40" of it
(length is not critical) and connect the other end to your MB
receiver. Put the unshielded 40" or so where it might be able to see
the ground without to much shielding from the airframe. There is your
MB antenna.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
Antoine de Saint-Exupry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
