mr.sun
Posted: Tue Sep 13, 2011 7:06 am Post subject: Overheating cylinder |
On a recent crosscountry flight at 8k and 2350 rpm, my IO360 started a wild fluxuation on #2 cht. My Skyview showed rapid movement between 300 and 550 degrees then it went out of range and stayed that way until landing. While taxiing all temps were normal and #2 egt stayed normal throughout the flight. When I pulled the cowl nothing looked cooked and sensor wire looked normal. Compression seemed normal when I pulled the prop through eight or ten times. I will swap egt sensors 2&4 next flight. Any other suggestions?
Greg On Sep 12, 2011 5:33 AM, "Linn Walters" <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)> wrote:> --> RV-List message posted by: Linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)>
| Quote: | Email Les Staples at SkyTek. Les Staples <les(at)skytecair.com (les(at)skytecair.com)>
He's more than willing to help. Tell him I sent ya.
Linn Walters
> On 9/11/2011 8:40 PM, Brian Huffaker wrote:
| Quote: | > --> RV-List message posted by: Brian Huffaker<bifft(at)xmission.com (bifft(at)xmission.com)>
> Got the exhaust system attached. It went together very easy, oneof the
>> simplest parts of this project so far. Everything just fit (once I filed
| Quote: | > the gaskets a little bit). Definatly recommend the Vetterman exaust if
> anybody is wondering.
> Looking ahead to later steps, I'm going to need a flywheel and starter
>> ring gear. Reading around, lycomings have either the 122 or 149 tooth
| Quote: | > gear, is there a way I can look at the starter I have and know which gear
> would fit? I can find lots of pages like this:
| Quote: | > http://www.skytecair.com/RingGearTech.htm
> explaining how to tell from the gear which it is, but nothing going the
> other way. It is a O-360A1D, so probably 149, but how can I know? Or
>> should I just get one, then get a new starter to match? That page talks
| Quote: | >
> Which says it is for a 122 tooth gear. Anybody know how to tell?
| Quote: | > Brian Huffaker, DSWL (bifft(at)xmission.com (bifft(at)xmission.com))
> RV-8A 80091 Hooking up engine.
> 1/4 Starduster II N23UT flying
="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
://forums.matronics.com">http://forums.matronics.com
min.
_________________ Greg RV-7 |
rv10rob(at)gmail.com Guest
Posted: Tue Sep 13, 2011 7:40 am Post subject: Overheating cylinder |
Try re-crimping the connectors before swapping the sensors.
On Tue, Sep 13, 2011 at 8:02 AM, <mr.gsun(at)gmail.com (mr.gsun(at)gmail.com)> wrote:
Linn Walters
| Quote: | > Got the exhaust system attached. It went together very easy, oneof the
| Quote: | >
| Quote: | > should I just get one, then get a new starter to match? That page talks
> about the first 3 digits of the starter model number, which is Delco-Remy
>> 1109519. Searching by that I find:
| Quote: | >
min.
t="_blank">http://www.matronics.com/Navigator?RV-List
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
mrobert569(at)hotmail.com Guest
Posted: Tue Sep 13, 2011 9:54 am Post subject: Overheating cylinder |
If everything there is OK try checking the injectors. Sometimes something will get into the fuel injectors that causes the spray pattern to go bad.
Mike Robertson
Date: Tue, 13 Sep 2011 08:37:34 -0700
Subject: Re: Re: Overheating cylinder
To: rv-list(at)matronics.com
| Quote: | On a recent crosscountry flight at 8k and 2350 rpm, my IO360 started a wild fluxuation on #2 cht. My Skyview showed rapid movement between 300 and 550 degrees then it went out of range and stayed that way until landing. While taxiing all temps were normal and #2 egt stayed normal throughout the flight. When I pulled the cowl nothing looked cooked and sensor wire looked normal. Compression seemed normal when I pulled the prop through eight or ten times. I will swap egt sensors 2&4 next flight. Any other suggestions?
Greg
| Quote: | --> RV-List message posted by: Linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)>
Linn Walters
> http://www.texasairsalvage.com/main_view.php?editid1=20144
min.
Rob Kochman
Woodinville, WA
get=_blank>http://www.matronics.com/Navigator?RV-List
=_blank>http://www.matronics.com/contribution
mr.sun
Posted: Tue Sep 13, 2011 10:22 am Post subject: Overheating cylinder |
Good thought, thanks. I will soak them in some Hoppe's #9. Would a cylinder with a dirty injector really run that much hotter?
Greg On Sep 13, 2011 10:58 AM, "Mike Robertson" <mrobert569(at)hotmail.com (mrobert569(at)hotmail.com)> wrote:>
| Quote: | If everything there is OK try checking the injectors. Sometimes something will get into the fuel injectors that causes the spray pattern to go bad.
> Greg
| Quote: | > Email Les Staples at SkyTek. Les Staples <les(at)skytecair.com (les(at)skytecair.com)>
> Linn Walters
| Quote: | >
| Quote: | >> Got the exhaust system attached. It went together very easy, oneof the
| Quote: | >>
| Quote: | >> explaining how to tell from the gear which it is, but nothing going the
| Quote: | >> Which says it is for a 122 tooth gear. Anybody know how to tell?
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Tue Sep 13, 2011 12:49 pm Post subject: Re: Overheating cylinder |
[quote="mr.sun"]Good thought,� thanks.�� I will soak them in some Hoppe's #9.��� Would a cylinder with a dirty injector really run that much hotter?���
Greg On Sep 13, 2011 10:58 AM, "Mike Robertson" <mrobert569> wrote:>
On Tue, Sep 13, 2011 at 8:02 AM, <mr> wrote:
> Greg
| Quote: | On Sep 12, 2011 5:33 AM, "Linn Walters" <pitts_pilot> wrote:
> --> RV-List message posted by: Linn Walters <pitts_pilot>
| Quote: | > Email Les Staples at SkyTek. Les Staples <les>
> Linn Walters
| Quote: | >
>> --> RV-List message posted by: Brian Huffaker<bifft>
| Quote: | >>
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Kellym
Posted: Tue Sep 13, 2011 2:09 pm Post subject: Overheating cylinder |
You won't have fluctuating values with a clogged injector. Only bad
probe wiring or a failing exhaust valve will cause rapid fluctation. In
the later case it will be a saw tooth pattern of maybe 50 degrees, and
your problem is far more likely to be a poor connection to the probe.
On 9/13/2011 12:19 PM, mr.gsun(at)gmail.com wrote:
Greg
pattern to go bad.
> Mike Robertson
> From: rv10rob(at)gmail.com <mailto:rv10rob(at)gmail.com>
> To: rv-list(at)matronics.com <mailto:rv-list(at)matronics.com>
> Greg
<mailto:pitts_pilot(at)bellsouth.net>> wrote:
<pitts_pilot(at)bellsouth.net <mailto:pitts_pilot(at)bellsouth.net>>
<mailto:les(at)skytecair.com>>
>> Linn Walters
<mailto:bifft(at)xmission.com>>
filed
which gear
going the
talks
Delco-Remy
>>> http://www.texasairsalvage.com/main_view.php?editid1 144
>>> Brian Huffaker, DSWL (bifft(at)xmission.com <mailto:bifft(at)xmission.com>)
<http://forums.matronics.com>">http://forums.matronics.com
> min.
> ttp://forums.matronics.com <http://forums.matronics.com>
> _blank">http://www.matronics.com/contribution
> Rob Kochman
> Woodinville, WA
KCHD |
mr.sun
Posted: Tue Sep 13, 2011 2:37 pm Post subject: Overheating cylinder |
Thanks. Interesting that it cools down and becomes normal moments after landing. But not on a long descent. Airflow thru cowl affecting poor crimp connection. Will recrimp wires and clean injectors this weelend.
Greg On Sep 13, 2011 3:15 PM, "Kelly McMullen" <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:> --> RV-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
| Quote: | You won't have fluctuating values with a clogged injector. Only bad
| Quote: | > >
>> pattern to go bad.
| Quote: | > > Try re-crimping the connectors before swapping the sensors.
>> <mailto:mr.gsun(at)gmail.com (mr.gsun(at)gmail.com)>> wrote:
| Quote: | > >
| Quote: | > until landing. While taxiing all temps were normal and #2 egt stayed
| Quote: | > pulled the prop through eight or ten times. I will swap egt sensors
>> > Greg
| Quote: | > >> Email Les Staples at SkyTek. Les Staples <les(at)skytecair.com (les(at)skytecair.com)
> <mailto:les(at)skytecair.com (les(at)skytecair.com)>>
| Quote: | > >> Linn Walters
>> <mailto:bifft(at)xmission.com (bifft(at)xmission.com)>>
| Quote: | > >>>
| Quote: | > filed
| Quote: | > >>> Looking ahead to later steps, I'm going to need a flywheel and starter
>> which gear
| Quote: | > >>> explaining how to tell from the gear which it is, but nothing
> going the
| Quote: | > talks
> Delco-Remy
| Quote: | > >>> Which says it is for a 122 tooth gear. Anybody know how to tell?
> >>> Brian Huffaker, DSWL (bifft(at)xmission.com (bifft(at)xmission.com) <mailto:bifft(at)xmission.com (bifft(at)xmission.com)>)
| Quote: | > >
> > Rob Kochman
> > Woodinville, WA
| Quote: | > >
>re, and much much more:
TRONICS WEB FORUMS -
nics.com/contribution">http://www.matronics.com/contribution
Posted: Tue Sep 13, 2011 3:23 pm Post subject: Overheating cylinder |
If it was an injector, wouldn't you be seeing high EGT, too?
On Tue, Sep 13, 2011 at 3:34 PM, <mr.gsun(at)gmail.com (mr.gsun(at)gmail.com)> wrote:
>> <mailto:mrobert569(at)hotmail.com (mrobert569(at)hotmail.com)>> wrote:
| Quote: | > >
| Quote: | > pattern to go bad.
> > Mike Robertson
| Quote: | > > Date: Tue, 13 Sep 2011 08:37:34 -0700
| Quote: | > >
| Quote: | > >
| Quote: | > 300 and 550 degrees then it went out of range and stayed that way
| Quote: | > cooked and sensor wire looked normal. Compression seemed normal when I
>> <mailto:pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)>> wrote:
| Quote: | > >> --> RV-List message posted by: Linn Walters
| Quote: | > <mailto:les(at)skytecair.com (les(at)skytecair.com)>>
> >> Linn Walters
| Quote: | > <mailto:bifft(at)xmission.com (bifft(at)xmission.com)>>
>> filed
| Quote: | > >>> the gaskets a little bit). Definatly recommend the Vetterman exaust if
| Quote: | > >>> gear, is there a way I can look at the starter I have and know
> which gear
| Quote: | > >>> other way. It is a O-360A1D, so probably 149, but how can I know? Or
> talks
| Quote: | >re, and much much more:
Rob Kochman
Woodinville, WA
Paul Valovich
Posted: Wed Sep 14, 2011 5:42 am Post subject: Overheating cylinder |
I had the same thing happen to me on 2 cylinders on 2 separate occasions during early phase 1 (new Aerosport IO-360). First time it was an obvious wiring issue – bad crimp that would intermittently make proper contact. The second time was also a wiring issue – but took a lot longer to discover. At first glance everything appeared ok – but more careful inspection revealed a loose wire.
In my case the temp variations were so rapid and extreme that I concluded the problem had to be electrical – not actual overheating. Sure got my attention, though.
Posted: Wed Sep 14, 2011 2:50 pm Post subject: Overheating cylinder |
It is possible. It happened to me, and after many injector cleanings and hunting we found it to be a bad flow divider. Not likely, but a possibility. Electrical is more likely.
Mike Robertson
Date: Tue, 13 Sep 2011 11:19:27 -0700
Subject: RE: Re: Overheating cylinder
Greg
Mike Robertson
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Greg
> Linn Walters
min.
Rob Kochman
Woodinville, WA
bicyclop(at)pacbell.net Guest
Posted: Wed Sep 14, 2011 2:57 pm Post subject: Overheating cylinder |
After I overhauled our engine, I had a cylinder reading 800+ degrees on my first flight. It was running way too well to be almost melted so I decided to ignore it, but also landed on my next circuit just to check it out. It turned out to be a loose connection at the probe.
Pax,
Ed Holyoke
On 9/14/2011 6:38 AM, Valovich, Paul wrote: [quote] <![endif]--> <![endif]-->
