Posted: Fri Sep 23, 2011 2:30 pm Post subject: Dynon roll servo settings? |
Which Dynon System do you have? I have the Skyview and used factory settings. They've been pretty good for heading, but I'm still tweaking pitch. -Mike Kraus
On Sep 23, 2011, at 5:13 PM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
[quote]Anyone have a good set of Dynon roll servo settings for the RV-10? I feel like I've tried everything, and still am not happy with the result. Nav mode is rock solid, but heading mode wanders all over the place.
Thanks...
-Rob
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
rv10flyer(at)verizon.net Guest
Posted: Fri Sep 23, 2011 3:43 pm Post subject: Dynon roll servo settings? |
Rob;
I saw this in the manual. You may have already done this.
Compass Calibration Requirement:
The SkyView autopilot requires an accurate magnetic heading to operate efficiently and comfortably in heading mode and the radio-based VOR/NAV mode. Therefore it is critical that the ADAHRS be installed correctly, calibrated, and operating well in all attitudes.
I know you mentioned NAV worked so this may not be an issue, but hopefully it may help..
Sent: Friday, September 23, 2011 2:13 PM
To: rv10-list (rv10-list(at)matronics.com)
Subject: Dynon roll servo settings?
Thanks...
-Rob
Rob Kochman
Woodinville, WA
rv10rob(at)gmail.com Guest
Posted: Mon Sep 26, 2011 1:57 pm Post subject: Dynon roll servo settings? |
Thanks, guys... I'm using the legacy (D100) system. I did do all the calibration steps for the compass. My magnetometer is mounted on a shelf aft of the baggage bulkhead.
http://kochman.net/N819K/wp-content/uploads/2010/01/img_0853.jpg
Though I used nonferrous mounting hardware, the real seat belt cables pass a few inches by. Do you think that would be a problem? My understading is that this was a common mounting location.
Mike, it's weird we're having different problems. My pitch has been rock solid from day 1.
-Rob
On Fri, Sep 23, 2011 at 4:40 PM, Pascal <rv10flyer(at)verizon.net (rv10flyer(at)verizon.net)> wrote:
| Quote: | Rob;
Thanks...
-Rob
Rob Kochman
Woodinville, WA
Rob Kochman
Woodinville, WA
